    Custom pathing for ROMs/savegames
    20 Posts 8 Posters 8.4k Views
      ShootHere
      Yo!
      Dunno if this has been suggested before but an easy way to set the path for ROMs/savegames with some sort of GUI would be neat, especially if it updates all the necessary configuration files to point to the new location of this HD/USB Stick.
      I also like to change the directory of my savegames for easier backup. It would be neat if, besides this being a seperate folder, the folder itself would contain the different categories by defauls (like /savegames/snes/) etc. Now if I am not mistaking this does not work for all emulators as some of the non-lr emus want to save in the same location as the actual rom, but it would still make life a lot easier.
      Perhaps Sselph's scraper could also look at the ROMs path and scrape there? Saving a lot of questions about custom directory scraping.
      Just an idea!
      • herb_fargusH
        herb_fargus administrators @ShootHere
        @ShootHere you can already scrape into romfolders (you just need the latest update or wait for the 4.0 release)
          ShootHere
          Well there goes another one of my shots at a good idea! Hahahaha
          I am eagerly awaiting the 4.0 release! Especially the "Boot into Kodi first and if quit, go to ES"-thing is what really tingles my shingles
            MikeDave @herb_fargus
            @herb_fargus,
            Maybe I'm misunderstanding something here. Are we able to save .srm and .statefiles in a different directory in 4.0? Because that would be amazing. I have scripts to copy them out of the roms folder into a backup folder, but it would be great if I could just specify a separate directory. It would make backing up save data super easy.
            • herb_fargusH
              herb_fargus administrators @MikeDave
              @MikeDave you can already define where your save states go through the retroarch.cfg file. you just have to define the filepath for where you want them to be saved
                @herb_fargus Oh wow. I couldn't find it in the wiki, but now that I actually read through retroarch.cfg I see that it's literally the first thing in the file. Thank you.
                • herb_fargusH
                  @MikeDave yep, its not a super common/ well documented setting as most people are fine with the savestates in the same rom folder. just note that there are some issues with some emulators where defining the save state location won't work due to upstream issues (particularly with the mednafen/beetle emulators)
                    @herb_fargus OK. Good to know.
                    I also just found it in the wiki here. I just had to look through the Pages directory on the right.
                    FloobF 1 Reply Last reply Reply Quote 0
                    • FloobF
                      Floob @MikeDave
                      @MikeDave If you wanted you could do this on a per system basis if you wanted each system to have its own save game folder.
                      System specific retroarch.cfg id found in /opt/retropie/configs/{system-name}/retroarch.cfg
                        MikeDave @Floob
                        @Floob Good call. I'll definitely have to play around with different configs and see what I like.
                        • F
                          Flynn's
                          @herb_fargus
                          How do yo scrape into romfolders? I installed 4.0 RC1 and it scrapes to downloaded-images. I've used both Sselph's and built-in scrapper.
                          • herb_fargusH
                            herb_fargus administrators @Flynn's
                            @Flynn's update your setup script and it will be an option here: https://github.com/retropie/retropie-setup/wiki/scraper
                            • F
                              Flynn's @herb_fargus
                              @herb_fargus
                              Ah, I think I interpreted what you said incorrectly and since I only started using RetroPie as of ver. 4.0 RC1 I'm not sure what it use to be.
                              Previously, I assume downloaded-images was a folder with no subfolders but now it is?
                              Edit, I thought you said it would create an 'images' folder in the respective rom folders where the roms are held (as an option). But that is only if you have to use your own image
                              • N
                                nemo93
                                hi! I got issue with saving the .srm for various systems in a specific directory as specified in /opt/retropie/configs/{system-name}/retroarch.cfg. Let me take an example, for PSX. In my retroarch.cfg for that system I've added:
                                # Save all game saves to this directory.
                                savefile_directory = /opt/retropie/roms/psx/saves/
                                I created the saves directory at this very location. Then I launch some games but unfortunately the .srm files keep being saved next to the roms, in the same directory. It goes the same for all other systems (SNES, MD/GEN, PCE, etc).
                                What am I missing? Latest RP, PI2.
                                • FloobF
                                  Floob @nemo93
                                  @nemo93
                                  Presumably you created the /roms/psx folders as well, as they arent there by default?
                                  Therefore it could possibly be a permission issue?
                                  Your games by default are in
                                  /home/pi/RetroPie/roms/psx
                                  Your configs by default are in
                                  /opt/retropie/configs/psx
                                  • N
                                    nemo93
                                    That's what I thought at first. Yet I've created the saves directories over Samba hence no permission issue should occur. To be sure and to confirm here's the current permission sets still for the PSX saves directory. It looks fine by me.
                                    drwxr-xr-x   2 pi pi       4096 Aug  9 19:09 saves
                                    I could give a try and apply 777 to it...
                                    • N
                                      nemo93
                                      Ok still same issue. I'm unable to put the *.srm or *.fs files into a separate folder :( Perhaps I'm not using the proper directory in the retroarch.cfg?? Any toughts please?
                                      • N
                                        nemo93
                                        Well... I feel so stupid :((((( I didn't pay enough attention and my paths were completely wrong... /o\ I tried to save the *.srm into /opt/retropie/roms/<system>/saves/ which is non existing of course!! I changed that for /home/pi/RetroPie/roms/<system>/saves/ and it's all working now \o/
                                        silly me. Sorry for that :(
                                        EDIT: it works nicely for libretro cores with the notable exception of lr-fba-next (generating *.fs files). With that core the .fs are being saved next to the roms no matter you put in the retroarch.cfg...
                                        GrandMasterLynxG 1 Reply Last reply Reply Quote 0
                                        • GrandMasterLynxG
                                          GrandMasterLynx @nemo93
                                          @nemo93 said in Custom pathing for ROMs/savegames:
                                          I’m trying to do the same thing but the save files only go to one folder that the 1st line of code or whatever tells it to go to n I’m trying to have the save files for the system go to each system I have them for but it doesn’t work for me any help would be appreciated
                                            cyperghost @GrandMasterLynx
                                            @GrandMasterLynx I've written a small script SavePath that does the work for you. Read carefully the instructions!
                                            For the setup you want with the /home/pi/RetroPie/roms/<system>/saves/ feature you would use
                                            SavePath.sh all "/home/pi/RetroPie/roms/$1/saves"
                                            You need to activate the two save key in retroarch.cfg with nano /opt/retropie/configs/all/retroarch.cfg if you use the all parameter.
                                            • savefile_directory = ""
                                            • savestate_directory = ""
