    Running YAPE on Retropi
    yapecommodore plus
    7 Posts 4 Posters 957 Views
    • 1
      16bit
      Hi all,
      I have a pi4 and only just started using it. So far I have got Amiga and Atari ST games running on it. I now want to get Commodore plus 4 games running. I know I need the Yape core? is Yape the one I need and not Vice?
        Yape is not included in RetroPie. You can run Plus4 games with lr-vice or vice, by choosing the appropriate emulator from the Runcommand launch menu.
        1 2 Replies Last reply Reply Quote 0
        • 1
          16bit @mitu
          @mitu thanks, i'll give it a go
          • 1
            16bit @mitu
            @mitu Hi,
            Ive been looking for the VICE rom folder but there doesn't to be one. Do the C64 games have to go into another folder?
            stoney66S 1 Reply Last reply Reply Quote 0
            • stoney66S
              stoney66 @16bit
              @16bit The folder for vice is c64
              1 1 Reply Last reply Reply Quote 0
              • 1
                16bit @stoney66
                @stoney66 great thanks
                LolonoisL 1 Reply Last reply Reply Quote 0
                • LolonoisL
                  Lolonois @16bit
                  @16bit as other stated already there is no need to use YAPE. However, from my experience some of the more recent homebrew games only work with YAPE. You may consider this guide [1] to install retroarch xplus4 and YAPE alongside.
                  [1] https://retropie.org.uk/forum/topic/30671/howto-press-play-on-yape-making-the-most-out-of-c16-plus4-emulation
