    Switching player 1 and 2 with Xin Mo Dual Arcade controller
    3 Posts 2 Posters 1.4k Views
      kenno7
      Hello,
      I have a Xin Mo Dual Arcade controller.
      I've followed the instructions here https://github.com/retropie/retropie-setup/wiki/Xin-Mo-Controller and both player 1 and 2 are recognized and work.
      However, player 2 has two additional buttons that I would like to use for player 1 . .
      Is there a way to switch player 1 and 2 on this controller?
      Or alternatively, is there a way for hotkeys to work with player 2s controller?
      Thanks for your help
        meleu @kenno7
        @kenno7 said in Switching player 1 and 2 with Xin Mo Dual Arcade controller:
        Yes. Need to edit some config files.
        To change the input for libretro emulators you can also use this tool: https://github.com/meleu/RetroPie-joystick-selection
        In libretro emulators, only player1 can perform hotkey actions.
          kenno7
          Thanks a lot for that! It worked :)
