Scummvm usb problem...
I followed this: https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive tutorial to load all my roms from USB. It works great! But I cannot open the scummvm GUI to add my games (so they appear in the menu), has anyone else had this issue, and how do you fix this?
This is because the filesystem on your USB stick doesn't support some unix file permissions such as the executable flag.
However I have worked around this in the latest RetroPie-Setup so if you update the script, and update all install packages it should work.
