    Newbie 1st post.. IPAC4 and Retroarch.cfg question
    9 Posts 4 Posters 2.4k Views
      mulder79
      Long term follower but first timer poster
      I have spent months building my portable 4 player arcade control panel using the IPAC 4 interface and PI3. Each player has the following inputs
      Joystick direction = 4 Buttons
      Buttons = 6 buttons
      Start = 1 Button
      Select = 1 Button
      And that's for all 4 players which equals = 48 buttons
      I also have an escape button so in total I have 49 buttons
      My problem is that when am setting up the retroarch.cfg file for all these buttons I have run out of keys to use.
      Could you someone suggest what keys I should use and how I should input it on the retroarch.cfg file ?
      The keys I have used are the following
      A - Z = 26 keys
      0 - 9 = 10 keys
      ctrl Lctrl alt Ralt Rshift Space Enter UP DOWN LEFT RIGHT
      Just noticed that I could possibly use SHIFT as I have not already used that if that's ok ?
      Someone suggested I use the EQUAL button but I don't know how to enter that on the retroacrch.cfg file ? I have tried EQUAL and = to no avail.
      • H
        helm71
        You are supposed to be able to just hold a key in and it will skip it...
        For me however this appears not to work..
        • FloobF
          Floob
          @mulder79 Here are some that work
          https://github.com/libretro/RetroArch/issues/358
          H M 2 Replies Last reply Reply Quote 0
          • H
            helm71 @Floob
            @Floob Can you elaborate? I do not understand.. Did I read correctly that what I am tryuing to do simply does not work and I need to create the config file manually ?
              mulder79 @helm71
              @helm71 said in Newbie 1st post.. IPAC4 and Retroarch.cfg question:
              To setup up a control connected to the pie via usb such as my usb snes then your suggestion is fine
              • H
                helm71 @mulder79
                @mulder79 Does not appear to work though... My switches thru the ipac are recognised as "keyboard" and are recognised, but long pressing a switch does not make it skip keys.. Therefor the whole configuring keys gui does not work.. I do not have enough switches to cover all keys it want to assign..
                  mulder79 @helm71
                  @helm71
                  Are you using an Ipac 4 ?
                  how many buttons including direction and start select per player do you physically have ?
                    mulder79 @Floob
                    @Floob said in Newbie 1st post.. IPAC4 and Retroarch.cfg question:
                    thanks, i will give them a go
                    • L
                      leechfreak
                      Dear Mulder
                      I also want to install retropie to a 4 player arcade machine with ipac 4 and for each player:
                      Buttons = 6 buttons
                      Start = 1 Button
                      Select = 1 Button
                      Extra: Pause button, Credit button (only 1 or for all players)
                      Do you still have the retroarch.cfg file whicj I can use?
                      Marno, The Netherlands
