    No sound retroflag gpi case with pi zero w 2 (Solved)
    retroflag gpipi zero w 2 pla
    53 Posts 14 Posters 16.7k Views
      jpwhiting @Slime1982
      @slime1982 Thanks for the fixes. I tried some other cmdline.txt options that were needed previously and various config.txt but this got it working. I ended up removing the other cmdline.txt bits that I tried before from https://retropie.org.uk/forum/topic/26628/audio-issues-after-latest-raspbian-updates-june-2020
      I'm still hearing lots of buzzing during game play though. I've got the alsa device set to "default" and the sound device set to headphones have tried various settings in es menu but there always is a loud buzzing. Is it a bad connection to the gpio pins? everything else seems to work well (screen, buttons, etc.)
      Thanks, this zero 2 seems to work much better besides the sound issue.
      • H
        hyperwolf83 @jpwhiting
        @jpwhiting
        The following are my config.txt setting that worked for me. I got sound, wifi, and syncthing running with no isseues. I used the weekly retroarch pi 3 image dated 31 Oct. I also get correct stereo sound when using headphone port, with no static.
        # http://www.raspberrypi.org/documentation/configuration/config-txt.md
        #hdmi_safe=1
        #disable_overscan=1
        #overscan_left=16
        #overscan_right=16
        #overscan_top=16
        #overscan_bottom=16
        # overscan.
        #framebuffer_width=1280
        #framebuffer_height=720
        #hdmi_force_hotplug=1
        #hdmi_group=1
        #hdmi_mode=1
        #hdmi_drive=2
        # no display
        #config_hdmi_boost=4
        #arm_freq=800
        #dtparam=i2c_arm=on
        #dtparam=i2s=on
        #dtparam=spi=on
        # Uncomment this to enable the lirc-rpi module
        #dtoverlay=lirc-rpi
        #config_hdmi_boost=0
        # force hdmi while the tv can take time before sending the signal on the hdmi o$
        # uncomment for composite PAL
        #sdtv_mode=2
        # uncomment for lirc-rpi
        #dtoverlay=lirc-rpi
        # if you plug your tv at the same time as your rpi and that the rpi switches fr$
        boot_delay=3
        # uncomment if you don't want the rainbow at startup
        disable_splash=1
        # default CEC name
        cec_osd_name=gpicase
        dtparam=audio=on
        # Overclock
        gpu_mem_256=128
        gpu_mem_512=256
        gpu_mem_1024=512
        avoid_safe_mode=1
        kernel=zImage
        dtoverlay=audremap,pins_18_19,enable_jack=on
        display_rotate=1
        dtoverlay=dpi24
        overscan_left=0
        overscan_right=0
        overscan_top=0
        overscan_bottom=0
        framebuffer_width=320
        framebuffer_height=240
        enable_dpi_lcd=1
        display_default_lcd=1
        dpi_group=2
        dpi_mode=87
        dpi_output_format=0x6016
        #hdmi_timings=320 0 28 18 28 480 0 2 2 4 0 0 0 60 0 32000000 6
        hdmi_timings=240 1 38 10 20 320 1 20 4 4 0 0 0 60 0 6400000 1
        # dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
        avoid_safe_mode=1
        disable_pvt=1
        disable_audio_dither=1
        # dtoverlay=pwm-audio-pi-zero
        J M 2 Replies Last reply Reply Quote 1
          jpwhiting @hyperwolf83
          @hyperwolf83 Thanks. That seems to work well here. At first I still got the buzzing but I pressed on the back of the gpi case "cartridge" briefly and it went away completely. I probably have a loose connection in there somewhere.
          cnotoC 1 Reply Last reply Reply Quote 0
          • cnotoC
            cnoto @jpwhiting
            Just confirming that this worked for me and it is definitely worth updating your GPI projects with the pi zero 2. Much better performance!
            • L
              Lo0twig
              At first this works well but after updating the pi via raspiconfig the internal audio error returns.
              I tried to use the old config with no luck. Any ideas ?
              • L
                Lo0twig
                Ah i guess the solution is to copy the GPI-Case files again to the sd card after updating.
                  pumpytums @Slime1982
                  @slime1982
                  Hi,
                  It was the batteries I have another GPi and Zero 2 same issue even in Recallbox. Tried some rechargeables no problems at all.
                  Odd though it played games no problem which I would have thought would pull more amps.
                  So Amazon brand Alkaline batteries even new don't like the current draw.
                  Thanks for your help
                  suprjamiS 1 Reply Last reply Reply Quote 0
                  • suprjamiS
                    suprjami @pumpytums
                    @pumpytums I've seen a few posts saying decent batteries are needed with the Zero 2W in GPi case.
                    I have Ikea Ladda 2450 which seem to work.
                    I have also seen the Panasonic Eneloop Pro are a good choice.
                    • E
                      EG500
                      i had a gpi case, and for the life of me was never able to get the thing to work.
                      There was one point in time, after about a month of research, restarting the process 3 times and following every guide i could find, there was One time i was able to get the controls to work, the sound never worked, and the controls didnt work in any of the emulators.
                      After restarting, I couldnt get the controls to work in es at all, and recallbox wouldnt even boot up.
                      Id recommend staying away from the retroflag gpi case (plus the pi zero has always been pretty bad at emulation in general). Id recommend going with the Piboy dmg, it works with a pie 3 or 4, and just works perfectly right out of the box..
                      • retropieuser555R
                        retropieuser555 @EG500
                        @eg500 did you hold down select+left (or start+left) to change the controls? That's what seems to trick a lot of people up with the gpi.
                        The piboy is pretty much unavailable where I am as far as I can tell, unless I paid a big customs cost to import it.
                        Whereas retroflag's products do seem to be produced and sold quite widely so that is something to consider when choosing between the two. Extra buttons is pretty nice though
                        Pi 5 4GB
                        • E
                          EG500 @retropieuser555
                          @retropieuser555 yes i did, both ways, it just flat out doesnt work correctly. I was really dissappinted woth it, where as piboy has their own retropie image you just doenload instal and youre done
                            mcbdz29 @hyperwolf83
                            @hyperwolf83 Any use of having "avoid_safe_mode=1" twice ?
                            • W
                              WhirlyFan
                              @Slime1982 bless you. this was so painful trying to get this thing set up.
                              • mituM mitu referenced this topic on
