    Low vertical frame rate in emulation station.
    fps drop
    2 Posts 2 Posters 314 Views
    • 9
      99Credits
      Hi all,
      I’ve recently built a vertical bartop and paired it with a Pi3b+. Everything is working flawlessly in horizontal mode with a solid 60fps, but when I edit the config file to display_rotate=1 EmulationStation drops to 21 fps after a reboot. Has anyone else had this problem, and if so is there a fix?
        Using display_rotate needs more GPU memory and usually has a performance impact.
        What's your resolution ? What version of RetroPie are you using ?
