    Way to shutdown secondary pi when quit emulationstation?
    severserviceshutdownrpi4
    5 Posts 3 Posters 804 Views
      retroguy
      I have just set up my retropie on an ubuntu pc and have configured a secondary rpi4 to run my digital marquee. The secondary marquee runs on simpleServer from Visual-RetroPie-Control-Maps and LCDMarqueeUpdate. I got it working and everything looks good there.
      My issue is having a nice way to properly shut down both computers without using a hard power off (which is my current setup). I was thinking there is probably a way to use a similar service to control the rpi4 - where ubuntu would shut down using emulationsstation option but then send a signal to the rpi to shut down.
      Has anyone got something like this to work, or any ideas on how to do it. I imagine it would be pretty simple if one knew what they were doing (as I do not).
      • AddisonA
        Addison
        Immediate shutdown
        sudo shutdown -h now
        Shutdown in 20 minutes
        sudo shutdown -h 20
        Shutdown at 5:30 pm
        sudo shutdown -h 17:30
        Cancel shutdown
        sudo shutdown -c
          retroguy @Addison
          @addison said in Way to shutdown secondary pi when quit emulationstation?:
          Immediate shutdown
          sudo shutdown -h 20
          Shutdown at 5:30 pm
          Cancel shutdown
          sudo shutdown -c
          Thanks, Addison. This shows me how to shut it down through the cmd line or ssh. What I really would like to do is have no interaction with the rpi that runs the marquee. I would like to have a signal sent to it from the main computer (Ubuntu) which makes it shut down, and I want this automatically sent when I shut down the main computer through emulation station.
          Do you have any thoughts on how to do this?
            You can run a command via ssh from your Ubuntu system on the pi
            ssh user@<pi> sudo shutdown -h now
            You'll have to setup a passwordless ssh login from the Ubuntu to the Pi, you can use a key-based login (as shown here). This way you can run commands on the Pi without providing a user/pass to ssh.
            The command to shutdown your Pi can be hooked up to the EmulationStation shutdown event, in a script - see https://retropie.org.uk/docs/EmulationStation/#scripting.
              retroguy @mitu
              @mitu Thanks...this just might work. I'll give it a go and let you know.
              I appreciate the support.
