    Intel NUC11TNKI5 - building problem
    build failedintel nucc99 compiler
    7 Posts 2 Posters 929 Views
      A Former User
      Hello,
      I've encountered a problem with the installation of Retropie on Ubuntu 20.04. I followed these steps: https://retropie.org.uk/docs/Debian/ and I can not perform basic installation because I've got a lot of building errors. If I try to manually install a package, it is also unsuccessful. It was a clean Ubuntu installation at first, nothing was changed and everything is up to date.
      I was searching through log files and it seems that I've got a problem with C99 compiler, but gcc is installed. I also performed "sudo apt install build-essential" command and Kernel 5 update. It does not helped. I was searching for hours, but without any success. It is weird because I installed Retropie on NUC8i5BEK without any problems.
      Error log file:
      Log started at: Ut 21. december 2021, 17:58:31 CET
      RetroPie-Setup version: 4.7.19 (0afb041)
      System: x86 (x86_64) - Ubuntu 20.04.3 LTS - Linux Retropie 5.11.0-43-generic #47~20.04.2-Ubuntu SMP Mon Dec 13 11:06:56 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
      Installing dependencies for 'retroarch' : RetroArch - frontend to the libretro emulator cores - required by all lr-* emulators
      /home/retropie/RetroPie-Setup/tmp/build/retroarch /home/retropie/RetroPie-Setup
      Getting sources for 'retroarch' : RetroArch - frontend to the libretro emulator cores - required by all lr-* emulators
      HEAD is now at 8373ac6 Bump version to 1.9.7
      M configuration.c
      M configuration.h
      M frontend/drivers/platform_unix.c
      M retroarch.c
      HEAD is now in branch 'HEAD' at commit '8373ac67460cd0e092453bad6bb83e674b5af31a'
      Building 'retroarch' : RetroArch - frontend to the libretro emulator cores - required by all lr-* emulators
      Checking operating system ... Linux (Ubuntu 20.04.3 LTS 20.04)
      Checking for suitable working C compiler ... /usr/bin/gcc works
      Checking for suitable working C++ compiler ... /usr/bin/g++ works
      Checking for pkg-config ... /usr/bin/pkg-config
      Checking for availability of switch -std=gnu99 in /usr/bin/gcc ... no
      Checking for availability of switch -std=c99 in /usr/bin/gcc ... no
      Cannot find a C99 compatible compiler.
      rm -rf obj-unix
      rm -f retroarch
      rm -f .d
      config.mk is outdated or non-existing. Run ./configure again.
      make: * [Makefile:193: config.mk] Error 1
      Could not successfully build retroarch - RetroArch - frontend to the libretro emulator cores - required by all lr-
      emulators (/home/retropie/RetroPie-Setup/tmp/build/retroarch/retroarch not found).
      Log ended at: Ut 21. december 2021, 17:58:31 CET
      Total running time: 0 hours, 0 mins, 0 secs
      Could you please help me?
      Thanks a lot!
        What's the output of the following commands:
        gcc --version
        cc --version
          A Former User
          Oh, sorry, I forgot to mention this:
          gcc --version:
          gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0
          cc --version:
            OK, so gcc is not a symlink to another compiler, so it's the standard one. Can't think of any issues with Ubuntu 20.04, did you change any of the standard gcc default parameters ?
            Check in $HOME/RetroPie-Setup/tmp/build/retroarch, there should be a config.log file which may offer some indications of why it failed.
              A Former User
              Nope, I installed Ubuntu 20.04 from USB, updated it with system updater and then tried to install Retropie. Nothing else was changed.
              I can not find it very useful, maybe there's something messed with bad value "tigerlake" which is the name of NUC model (NUC11TNKI5 Tigerlake or something like that), but I do not understand it very much. There is a "cat config.log" command output:
              Command line invocation:
              $ ./configure --prefix=/opt/retropie/emulators/retroarch --disable-sdl --enable-sdl2 --disable-oss --disable-al --disable-jack --disable-qt --enable-vulkan
              Core Tests.
              cc1: error: bad value (‘tigerlake’) for ‘-march=’ switch
              cc1: note: valid arguments to ‘-march=’ switch are: nocona core2 nehalem corei7 westmere sandybridge corei7-avx ivybridge core-avx-i haswell core-avx2 broadwell skylake skylake-avx512 cannonlake icelake-client icelake-server cascadelake bonnell atom silvermont slm goldmont goldmont-plus tremont knl knm x86-64 eden-x2 nano nano-1000 nano-2000 nano-3000 nano-x2 eden-x4 nano-x4 k8 k8-sse3 opteron opteron-sse3 athlon64 athlon64-sse3 athlon-fx amdfam10 barcelona bdver1 bdver2 bdver3 bdver4 znver1 znver2 btver1 btver2 native
              cc1: error: bad value (‘tigerlake’) for ‘-mtune=’ switch
              cc1: note: valid arguments to ‘-mtune=’ switch are: nocona core2 nehalem corei7 westmere sandybridge corei7-avx ivybridge core-avx-i haswell core-avx2 broadwell skylake skylake-avx512 cannonlake icelake-client icelake-server cascadelake bonnell atom silvermont slm goldmont goldmont-plus tremont knl knm intel x86-64 eden-x2 nano nano-1000 nano-2000 nano-3000 nano-x2 eden-x4 nano-x4 k8 k8-sse3 opteron opteron-sse3 athlon64 athlon64-sse3 athlon-fx amdfam10 barcelona bdver1 bdver2 bdver3 bdver4 znver1 znver2 btver1 btver2 generic native
                Hm, looks like your NUC's CPU is newer and the default gcc on Ubuntu 20.04 doesn't known about it. Try installing gcc10 and set it as default compiler, see https://stackoverflow.com/questions/64493692/.
                  A Former User
                  Oh wow, it works!!!
                  I installed g++-10 and gcc-10 with:
                  sudo apt install g++-10
                  sudo apt install gcc-10
                  Then I ran this command:
                  sudo make CC=gcc-10 CPP=g++-10 CXX=g++-10 LD=g++-10
                  with error, because I had to run ./configure command again. So I did and then tried it again.
                  After that I've finally built retroarch core package and performed basic installation of Retropie.
                  I could not figure it out myself. Thank you for your direction, you're the best! ;)
