Help
Hi guys please help. My kid got into the config settings on my retropie. Now none of game work you can still view them in the menus but the wont play. Screen just goes blank for a couple seconds then it returns to the menu. Can this be fixed. Thanks alot
@gizpunk have you considered putting the kid up for adoption :)
Just kidding. You may need to post some pics of your configs for the experts to see what has changed -
@hawkes_84 ive gone into the retropie config menu what pictures should i take. Sorry new to this
This post is deleted! -
@gizpunk no worries. Welcome to Retropie fella. Not sure. Whichever screen your kid went to I guess if you can remember. It's probably something really simple like an extra letter has been added somewhere. Also it would have had to be saved for anything to take effect
Can this be fixed.
Probably. A verbose log from runcommand, (https://retropie.org.uk/docs/Runcommand/#launch-with-verbose-logging) and the ES logs from
~/.emulationstation/es_log.txt
andes_log.txt.bak
(from the network share:configs\all\emulationstation\es_log.txt
andes_log.txt.bak
) would be the place to start. Upload the logs to pastebin.com and share the links here. -
@sleve_mcdichael cheers will have a better look later on tonight please bere with me guys. Thanks
