    Little help with C64 emu Vice
    400raspberryretrocommodore
    2 Posts 2 Posters 497 Views
      Radamand
      I got retropie image with Vice on microSD card, my Pi400 now boots straight into "Commodore 64 Basic V2".
      I have software/some games, how do I load/run my games on the Pi400 C64??
      Do I put all my games onto a Flash drive and plug that into the Pi400?
      Or do I put them on the SD card?
        RetroPie doesn't boot into the Vice emulator by default, did you modify the auto-start sequence ?
        You can copy the game files (floppy/cassete images) in the c64 rom folder and you can then load them from the Vice menu. Normally, if you start in the EmulationStation front-end, they would be listed and you can just start each one from the list with vice/lr-vice.
        https://retropie.org.uk/docs/Transferring-Roms/
