    [SOLVED] N64 Mupen64Plus Controller Issue on GPi 2 Case
    n64 controlsmupen64plusinputautocfg
    3 Posts 2 Posters 956 Views
    • TPRT
      TPR
      I'm porting over my Pi 4 build to the GPi Case 2 and I have several of my N64 games running under Mupen64Plus-GlideN64. I need to remap the analog stick to the D-pad. I've followed the instructions in the RetroPie docs which say:
      There are two main configuration files that can be modified:
      /opt/retropie/configs/n64/mupen64plus.cfg
      /opt/retropie/configs/n64/InputAutoCfg.ini
      Note: Some arcade Joysticks or non-analogue controllers may need the following tweak to the generated mapping:
      X Axis = "hat(0 Left, 0 Right)"
      Y Axis = "hat(0 Up, 0 Down)"
      To
      X Axis = "hat(0 Left Right)"
      Y Axis = "hat(0 Up Down)"
      However, when I change the controls to:
      The only movement I get is Left and Up. I have tried both configs suggested above, the first one doesn't work at all, the second one only gives me Left and Up.
      Any ideas on what that config file needs to say in order for me to get all four directions?
      Thank you.
      • TPRT
        TPR
        SOLVED!
        The correct syntax needs to be this in the InputAutoCfg.ini:
        X Axis = hat(0 Left Right)
        Y Axis = hat(0 Up Down)
        Remove the quotes.
        I'm not sure if the instructions in the RetroPie doc are wrong or something has changed recently, but that fix worked for me.
          julenvito @TPR
          @TPR said in [SOLVED] N64 Mupen64Plus Controller Issue on GPi 2 Case:
          SOLVED!
          Remove the quotes.
          Hi! Thank you very much for the contribution, it works perfectly! I have another question… Does the audio work well for you with mupen64plus? Many thanks!
