    USB power pass through question - Arcade stick all-in-one
    power supplypass through
    3 Posts 2 Posters 595 Views
    • V
      ViciousCRC
      Pi Model or other hardware: B+
      Power Supply used: need a solution for a pass through to use case enclosure
      USB Devices connected: Brook Universal Fighting Board
      USB Devices connected: same as above
      Context:
      I have like 3 arcade sticks, and I was planning to use one of the cases to have an all-in-one build; my idea is for the case to contain the following
      The normal Arcade Stick build
      • Brook Universal Fighting Board PCB (PS3/PS4/XBOX...)
      • Joystick
      • 8x 30mm pushbuttons
      • 6x 24mm pushbuttons
      • 20-pin wiring harness
      • Short USB A-B (splitter to connect one to the Pi as main controller)
      • Neutrik USB pass through
      • External USB cable A-B
      And I want to add
      • Raspberry Pi using a Retro-pi Build
      • Neutrik HDMI pass through
      • internal / external HDMI cables
      • Additional Neutrik USB pass through to connect another controller to the Raspberry Pi (or maybe a keyboard when needed)
      • Micro USB pass through (THIS IS MY QUESTION), I have a Raspberry B and B+
      I don't want to have any direct connections to the Raspberry from the outside, I've been browsing for a couple of hours but I haven't seen anything that can help me accomplishing this
      I just want to be able to plug both HDMI and Power on the case enclosure and have 2 internal cables to connect to the raspberry, but I need help on the power passthrough solution, any ideas or suggestions?
      Y 1 Reply Last reply Reply Quote 0
      • Y
        yserra @ViciousCRC
        @viciouscrc isn't a simple pass through cable like this one enough?
        https://www.amazon.fr/CERRXIAN-broches-chargement-synchronisation-Motorola/dp/B071V8LYJC/ref=sr_1_9?__mk_fr_FR=ÅMÅŽÕÑ&crid=3CNBMMB5JY7V1&keywords=rallonge+micro+usb+20+cm&qid=1644493692&sprefix=rallonge+micro+usb+20+cm%2Caps%2C57&sr=8-9
        • V
          ViciousCRC @yserra
          @yserra man... now I feel dumb hahaha you don't know how many things I searched for and I never saw those, thanks.
          I'll buy that thing and post pics and all once the project is complete
