    No sound in Kodi [solved]
    kodi
    6 Posts 2 Posters 2.5k Views
    • saccublendaS
      saccublenda
      Hello, I did not use Kodi in RetroPie for some times, and today I found out that I have no audio in Kodi, while audio is still working in ES.
      I don't know if this is due to some recent changes, does anyone else have the same problem?
      Pi Model or other hardware: pi4 4gb
      Power Supply used: USB3.0
      RetroPie Version Used: 4.7.21
      Built From: https://github.com/RetroPie/RetroPie-Setup/releases/download/4.7.1/retropie-buster-4.7.1-rpi4_400.img.gz
      USB Devices connected: bluetooth dongle
      Controller used: 8bitdo sfc30 (bluetooth)
      • windgW
        windg
        Go to settings > system > audio and check the audio output device. What is your settings there ?
        saccublendaS 1 Reply Last reply Reply Quote 0
        • saccublendaS
          saccublenda @windg
          @windg It is set on the default PI: HDMI, I did however tried all the other output devices and none works.
          • windgW
            windg
            Try to remove and install again kodi. Don't forget to backup your settings.
            • saccublendaS
              saccublenda @windg
              @windg Removed Kodi and then reinstalled it, still no audio.
              • saccublendaS
                saccublenda @saccublenda
                Ok, this is embarrassing.
                It turned out that (for some reason) the volume was set to -60 db in the playback audio setting, and this (for some reason) affects also the Kodi UI sound volume. The playback audio settings are separated from the general settings > system > audio, but the playback audio can be modified pressing the keyboard keys + and -. This, coupled with the weird behavior of Kodi that (for some reason) does not play UI sounds when using a controller, but only when using a keyboard.
                It turned out to be a rather silly problem, but I leave it here hoping this can help others facing the same behavior.
