8BitDo P30 classic Modkit Mapping Problem [solved]
Hi friends
I have 7 modkits of 8bit do (2 PlayStation Classic, 2 SNES, 2 NES, 1 SEGA) and only I have the mapping problem with PlayStation P30 Classic 8BitDo modkit.
I describe the problem step by step:
- First of all, I have mapped all controllers and all buttons.
- I have updated Retropie on my Raspberry Pi at the last version.
- I turn on the Raspberry Pi
- I turn on one of PlayStation Controller.
Now the controller change the saved mapping configuration of two buttons. A (Circle) and B (Cross).
If i turn one the second controler works fine, but the first of PlayStation that I connect fails and not load the correctly mapping.
Details
- I discard controller problem because if I change the order of conection of the controllers always fail the mapping of the first that I connect.
Thanks in advance for the support
+info Reddit: View Post
Are both PS controllers identical ? If they produce diferent input codes for the A/B buttons, but have the same name, auto-configuration won't work.
ES (and other emulators) identify the controllers by their name. If both PS controllers are named the same, they'll share the same configuration.
However if button A has input codeX
on a controller, but produces input codeY
on the other, you'll get this kind of issue.Are the controllers pairs in the same 'connect mode' - i.e. Switch/XInput/etc. ? If they're not, the buttons may have different behaviors depending on the connection mode.
@mitu first of all thanks for the fast reply.
- When you say that "controllers are identicals?" What are you talking about?
The controllers have diferent Bluetooth identificator. But that dont reply your question. - The controllers have the same name. You can see the list of paired items
- All my controllers have the same 'connect mode' because is a requirement of 8bitdo to sync with my Raspberry Pi. At least that's what I was told was necessary to sync with the Raspberry Pi.
Thanks for your help & your time
@danny007 said in 8BitDo P30 classic Modkit Mapping Problem:
I was asking if the PS classic controllers are identical and they're not different vendor/models. Since they connect via the modkit, their model is 'obscured' by the Bluetooth adapter.
The controllers have the same name. You can see the list of paired itemsOk, so they have the same name.
You need to check if they also produce the same inputs for the problematic buttons. You can check this with
jstest
, from the command line.Exit EmulationStation and just with one of the controllers connected (one of the 2 PS Classic) run
jstest /dev/input/js0
Press the ◯ (Circle) and the X buttons and note the button numbers that are toggled on screen. Press
Ctrl + C
to stop the testThen, connect the other PS Classic controller and repeat the test. See if the button numbers match for both controllers.
@mitu said in 8BitDo P30 classic Modkit Mapping Problem:
PS classic controllers are identical. Same vendor and same model. Info 8BitDo.
You need to check if they also produce the same inputs for the problematic buttons. You can check this with jstest, from the command line.
jstest /dev/input/js0Press the ◯ (Circle) and the X buttons and note the button numbers that are toggled on screen. Press Ctrl + C to stop the test
Then, connect the other PS Classic controller and repeat the test. See if the button numbers match for both controllers.- I connect PS Classic controller 1 and I make the test with result:
O - 1
X - 0
- I shut down PS Classic controller 1
- I connect PS Classic controller 2 and I make the test with result:
O - 0
X - 1
O - 1
X - 0
O - 0
X - 1Do you see the issue here ? Though they're the same, they have different button actions - A and B (East/South) are switched.
Since they're identified by the same name (8BitDo P30 modkit), they're using the same configuration and that's why the mapping is incorrect for one of them.
Nothing much that RetroPie can do here - can you check if the modkit firmware is identical, maybe upgrade it on both ?EDIT: now that I think of it, would it be possible that the modkit connection to the gamepad's buttons are different ? So that A/East is connected on 1st gamepad to the same modkit connection as B/South on the 2nd (and vice-versa) ?Hm, looking at the schematics of the modkit, this doesn't seem possible. -
Nothing much that RetroPie can do here - can you check if the modkit firmware is identical, maybe upgrade it on both ?I have tryed to force mapping "incorrectly" in one of that. For example put one of the controllers the X and O interchanged but... saving the configuration by name...
Other curiosity, to see your oppinion is...
Do you think the next info have logical? I turn on controller 1 first and later controller 2 the first controller will have incorrect mapping. I shut down the sistem and restart. I turn on controller 2 first and next the 1 and the controller 2 that I turn on first have incorrect mapping.
In summary, the problem is in the controller?
I have other 2 NES and having same name... etc... works fine
I have other 2 of SNES and having same name... etc... works fine -
I don't think it's the controller, but the 8BitDo modkit. Try updating the firmware on both, just to make sure they have the same version.
Sorry, when I said controller I wanted to say 8BitDo modkit or gamepad.
This afternoon I try the update tool to see if there are new versions since I just checked that there are people who have updated the modkit.
I know the reason that I thought that modkits not able to update. In the 8BitDo support site, only appears the option "Firmware Updater" into original controllers, not modkits. However seems that if you connect modkit can be updated.
https://imgur.com/gallery/ZKm3oUu
I will give updates about that
This post is deleted! -
I update all my 7 8BitDo modkits
- Desarm and connect
- Update
I read that one of the updates fix the issue of A and B being mixed up. Maybe my problem true?
- Test Result = Same problem that I have before
Modkit 1
O - 0
X - 1
Modkit 2
O - 1
X - 0
As shown by testing, yes.
If the issue still persists after updating the firmware, then you may want to send an email to 8BitDo support and let them know it's not working for you.
I'm still waiting for a response from technical support...
Hallelujah
Works Fine. 8BitDo give me the easy 🥺... solution.
Hold SELECT + DPAD DOWN = Switch the positions of the A-B and X-Y keys8BidDo SOLUTION Video
Big thanks to your support @mitu
Glad you got it sorted out and thanks for adding the solution to the topic.
It would be nice if 8BitDo would include this info in the Modkit manual, they are mentioning _ SELECT + DPAD DOWN_ as a way to send the Home button only when the modkit is paired in Switch mode.
I'll mark this topic as solved.
