    [SOLVED] 8bitdo NES30 PRO start+select combo not working (Retropie 4.0-rc1)
    10 Posts 3 Posters 13.2k Views
      msxer
      Hi, I have just received my new 8bitdo NES30 PRO bluetooth gamepad and I'm struggling to make it work nicely on my Retropie 4.0-rc1 installation (source-updated from the 3.8.1 image.
      The controls are working fine on my noname USB retro (SNES style) gamepads but on the NES30 PRO controller I can't exit from the Retroarch cores using start+select.
      The NES30 PRO controller came with firmware v1.70 (beta) which I downgraded to v1.69. Pairing the controller to my Pi3 (with built-in bluetooth) worked fine. I'm using the NES30 PRO controller in Mode 1 (Joystick).
      Dit anyone get this controller to work correctly in Retropie?
        edmaul69 @msxer
        @msxer all three i set up work fine. Look in /opt/retropie/configs/all/retroarch-joypads/8BitdoNES30Pro.cfg and see if everything is correct in there. I will post the correct settings in a second i need to switch to my computer
          edmaul69
          input_device = "8Bitdo NES30 Pro"
          input_driver = "sdl2"
          input_select_btn = "10"
          input_start_btn = "11"
          input_a_btn = "0"
          input_b_btn = "1"
          input_y_btn = "4"
          input_x_btn = "3"
          input_l_btn = "6"
          input_r_btn = "7"
          input_l2_btn = "8"
          input_r2_btn = "9"
          input_l3_btn = "13"
          input_r3_btn = "14"
          input_up_btn = "h0up"
          input_down_btn = "h0down"
          input_left_btn = "h0left"
          input_right_btn = "h0right"
          input_l_x_plus_axis = "+0"
          input_l_x_minus_axis = "-0"
          input_l_y_plus_axis = "+1"
          input_l_y_minus_axis = "-1"
          input_r_x_plus_axis = "+2"
          input_r_x_minus_axis = "-2"
          input_r_y_plus_axis = "+3"
          input_r_y_minus_axis = "-3"
          input_exit_emulator_btn = "11"
          input_enable_hotkey_btn = "10"
            msxer @edmaul69
            @edmaul69 said in 8bitdo NES30 PRO start+select combo not working (Retropie 4.0-rc1):
            Thanks!!
            My 8BitdoNES30Pro.cfg was quite different from yours, so I just copied all of your values to mine and now it seems to be working great!
            My old 8BitdoNES30Pro.cfg was as follows (don't know why):
            input_driver = "udev"
            input_l3_btn = "24"
            input_l_btn = "17"
            input_load_state_btn = "17"
            input_start_btn = "22"
            input_exit_emulator_btn = "22"
            input_a_btn = "11"
            input_b_btn = "12"
            input_reset_btn = "12"
            input_r_btn = "18"
            input_save_state_btn = "18"
            input_r2_btn = "20"
            input_r3_btn = "25"
            input_x_btn = "14"
            input_menu_toggle_btn = "14"
            input_select_btn = "21"
            input_enable_hotkey_btn = "21"
            input_y_btn = "15"
            input_l2_btn = "19"
            • FloobF
              Floob
              @msxer Would you mind trying this udev based controller file to test please?
              It includes all the hotkeys that ES adds to the file.
              input_l3_btn = "13"
              input_l_btn = "6"
              input_load_state_btn = "6"
              input_a_btn = "0"
              input_b_btn = "1"
              input_reset_btn = "1"
              input_r_btn = "7"
              input_save_state_btn = "7"
              input_r3_btn = "14"
              input_x_btn = "3"
              input_menu_toggle_btn = "3"
              input_y_btn = "4"
                msxer @Floob
                @Floob said in 8bitdo NES30 PRO start+select combo not working (Retropie 4.0-rc1):
                input_l3_btn = "13"
                input_l_btn = "6"
                input_a_btn = "0"
                input_b_btn = "1"
                input_r_btn = "7"
                input_r3_btn = "14"
                input_x_btn = "3"
                input_y_btn = "4"
                Thanks @Floob, that one works even better. Now the Retroarch menu (select+X) is also working.
                The only thing now that doesn't seem to work is the analog stick in Playstation games (was the same with @edmaul69's sdl2 based config file. The Playstation emulator complains that no analog controller is connected. I have not really looked at Playstation before, so it could be a generic problem with all controllers.
                I also found out that the incorrect 8BitdoNES30Pro.cfg is created when I use the Configure Input menu in Emulation Station. So I'm not doing that anymore for my NES30 PRO.
                • FloobF
                  Floob
                  This shows how to get the analog controls working, I havent tried it recently but it should be fine:
                  ?t=333
                  Also, please note Emulation Station does create the configs correctly (thats where mine came from above), the issue is getting the right combo of 8bitdo controller / firmware / hack setting.
                  So for example, with your NES30 Pro on firmware 1.69, if you disable the hack, re-register the controller, go into ES and re-generate the controls it should be just fine.
                    edmaul69 @msxer
                    @msxer sorry i left those options out when i posted as i have them set up different.
                      msxer @Floob
                      Thanks again! How can I enable/disable the hack setting (and what does it do?). I don't recall enabling any hack.
                      Edit: Nevermind, I found the switch to enable/disable the 8Bitdo mapping hack in the Retropie-Setup > Bluetooth menu. It seems the default setting is "ON - old firmware". So I turned it off, re-paired the NES30 PRO and re-generated the controls from within ES and indeed they were (almost, see below) the same as the ones you described.
                      There are 2 additional lines in my new 8BitdoNES30Pro.cfg because I also entered the L2 and R2 shoulder buttons:
                      input_r2_btn = "9"
                      input_l2_btn = "8"
                      • FloobF
                        Floob
                        @msxer Ah - yes good point, I always forget about those :)
                        Glad its all working well now.
