    Commodore 128 custom rom not changing.
    vice c128
    3 Posts 2 Posters 278 Views
      kevgal
      Pie 4
      Retroarch
      Emulastion Station
      Gday guys I'm trying to run Elite 128 in GO64 mode by using this custom rom feature
      vice_c128_go64= "enabled"
      but it stays in 128 mode.
      From libretto docs-
      "GO64 (Restart) [vice_c128_go64] (disabled|enabled)"
      I'm not sure what it means by "Restart".
      I've tried rebooting via the virtual keyboard and restarting the system but it still stays in 128 mode.
      What have I missed?
      Cheers
      Kev
        @kevgal said in Commodore 128 custom rom not changing.:
        Not sure where you add this info, but you don't need to add it manually. Just start the game with lr-vice-x128, then go into Core Options -> System and choose ON for the GO64 option. When closing the RetroArch menu, the system should restart automatically and start the game with the correct options.
        Note that you may want to save this set of options just for this game, leaving the GO64 option untouched for the rest of the C128 ROMs.
          kevgal @mitu
          @mitu Thanks that works, not sure why the other method doesn't though,
          Cheers
