    System artwork not generating with scraper
    scraper
    4 Posts 2 Posters 435 Views
      psun03
      I am having trouble with updating my games' art work for one of my systems. I tried using the default scrapper that is built into RetroPie and also tried using SkyScrapper.
      I want the system to show video of the games when I over the games. How can I get the scrapper to generate the correct video. Which scrapper do you guys recommend?
      Pi Model or other hardware: P4 8gb
      Power Supply used: 5v 2A
      RetroPie Version Used: 4.7
      Built From: Pre-made SD Image on RetroPie website
      USB Devices connected: none
      Controller used: wii u pro controller
        sleve_mcdichael @psun03
        @psun03 Skyscraper + screenscraper = videos.
          psun03
          the other problem is it is not update one of my systems period..
            @psun03 which system? Is it one of the supported platforms?
            https://github.com/muldjord/skyscraper/blob/master/docs/PLATFORMS.md
