    VolumeControl::getVolume() - Failed to get volume range!
    audioubuntu
    2 Posts 2 Posters 328 Views
      McJones9631
      I have a PC converted to Retropie running on Xubuntu, and I have a speaker routed through the headphone Jack on the motherboard. When trying to turn up the volume on the audio menu, the slider reverts back to 0 when reopened. When attempting to launch Retropie setup, a snippet of backend code became visible:
      VolumeControl::init() - Failed to find mixer elements!
      This repeats itself twice. What am I doing wrong that is causing this issue? I’m running version 4.7.18 on Ubuntu 21.04
        Can you run, from a terminal, the following commands:
        aplay -l
        aplay -L
        and post the output ? The error in EmulationStation logs indicated the audio settings for the volume control are not correct. Do you have sound during gameplay, when running the emulators ?
