    Newest system
    8 Posts 4 Posters 3.0k Views
      Barraccus
      What is the newest system that RetroPie can support?
        movisman
        Newest system? Not sure, without going experimental and sticking with stable emulators, I guess the PSX?! I might be wrong.
          Barraccus
          Thank you for the reply
            dankcushions Global Moderator
            stock retropie supports PSP, from 2004/2005. any advance on that? :)
              movisman
              Ha, I was going to mention PSP but thought it was still experimental or had poor performance! Might have a look at it at some point.
                it's not in the experimental menu, it's available in a stock build, but performance can for sure be poor!
                  Twitch0815
                  However PSP on an overclocked Pi 3 with framerate skip 1 can get some pretty playable results. Far from stable but a few games play pretty well.
                    movisman
                    I also realised quite how old the PSX is compared to the other systems, released in 1995 in Europe, 1994 in Japan! Even older than the N64.
