    Power Button in 2022
    power button2022
    6 Posts 2 Posters 1.1k Views
    • L
      lindsay
      Retropie 4.8
      Raspberry Pi 4 2GB
      Official power adaptor
      PS3 controller
      lr-Mame 2003 (0.78) and 2010
      Hi All,
      What is the current recommendation for power buttons and script to run them?
      I tried following old ETA Prime tutorials but they didn't work with Retropie 4.8
      Also on this forum the latest I could find was from 2 years ago.
      Thanks so much
      • L
        lindsay @lindsay
        @lindsay
        Redirecting the output of rc.local to a log file yielded this error:
        • sudo python /home/pi/scripts/shutdown.py
          Traceback (most recent call last):
          File "/home/pi/scripts/shutdown.py", line 3, in <module>
          import RPi.GPIO as GPIO
          RuntimeError: This module can only be run on a Raspberry Pi!
        Well, it definitely is being run on a Raspberry pi!
          Save yourself the trouble and use @cyperghost's shutdown script - it's at https://github.com/crcerror/ES-generic-shutdown.
          L 1 Reply Last reply Reply Quote 1
          • L
            lindsay @mitu
            @mitu thanks, this is from 2018, does it still work in 2022?
            And it seems it needs special case with a special power switch installed, or am I mistaken?
              mitu Global Moderator @lindsay
              @lindsay said in Power Button in 2022:
              Yes.
              No, it supports a number of special power switches, but it works also with a generic GPIO button.
              • L
                lindsay @mitu
                @mitu Many thanks.
