    RetroPie 4 Configuration Settings Not Working
    config
    3 Posts 2 Posters 419 Views
      GameCodingNinja
      New to RetroPie and having a blast! Downloaded and flashed the latest 4.8 releases for the Raspberry PI 3 & 4.
      I have been bouncing between the two as I setup my games. Wanted to check the performance on the different PI's and experiment with the Scrapper but needed to setup my WIFI settings. The configuration settings works on the PI 3 but for the PI 4, fades to a black and doesn't come out. I usually have to power cycle the PI at that point.
      I figure it might have something to do with my computer monitor (2560x1440). Unfortunately I don't have access to a different monitor.
      I can work around it by setting up the WIFI on my PI 3 and do the scrapping there. Just wanted to share my experience.
        @GameCodingNinja said in RetroPie 4 Configuration Settings Not Working:
        Force 1080p on your Pi4 - https://retropie.org.uk/docs/Pi4/#issues-using-a-4k-tv.
          GameCodingNinja @mitu
          Thanks you I'll give that a try.
