    Donkey Kong color palette for FBNeo hacked into mame2003-libretro
    fbneomame2003color wrongdonkey kong
    48 Posts 8 Posters 9.6k Views
      capcob
      Re: Colors Are Off In Mame-2003
      ******* Hack to fix Mame 2003 ( libretro ) Donkey Kong colours in Retropie ******
      On my Retropie I rebuilt the latest FBNeo-libretro source with some logging to record the 'correct' palette which is shown below.
      In mame2003-libretro I then hard coded these palette values to replace the 'incorrect' calculated palette values and rebuilt.
      I also removed the warning associated with inaccurate colours.
      Before anyone screams, I've no plans to pollute the code base with this frankly monstrous hack but it does the job for me on a practical level.
      static int FBNeoPalette[256][4] =
          { 0, 0, 0, 0 },
          { 9145343, 139, 139, 255 },
          { 57855, 0, 225, 255 },
          { 14745600, 225, 0, 0 },
          { 0, 0, 0, 0 },
          { 14788352, 225, 167, 0 },
          { 14803455, 225, 225, 255 },
          { 0, 0, 0, 0 },
          { 14788490, 225, 167, 138 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 57600, 0, 225, 0 },
          { 0, 0, 0, 0 },
          { 14771712, 225, 102, 0 },
          { 0, 0, 0, 0 },
          { 14745818, 225, 0, 218 },
          { 14803200, 225, 225, 0 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 10944512, 167, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 14763994, 225, 71, 218 },
          { 0, 0, 0, 0 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 12946314, 197, 139, 138 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 14754954, 225, 36, 138 },
          { 9109504, 139, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 218, 0, 0, 218 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 },
          { 255, 0, 0, 255 },
          { 0, 0, 0, 0 },
          { 0, 0, 0, 0 }
      BuZzB 1 Reply Last reply Reply Quote 2
        barbudreadmon
        @capcob said in Donkey Kong color palette for FBNeo hacked into mame2003-libretro:
        Just wondering, why bother doing this when you could simply use emulators with the correct palette ?
          capcob @barbudreadmon
          @barbudreadmon - its a good question.
          I guess I've spent a while building a system that only uses mame2003-libretro and which in almost every other respect I like - the hack was easy enough and I didn't like being forced to use a different core for one game.
            BuZz administrators @capcob
            @capcob Please wrap code / logs in three backticks above and below. I have edited your post. See http://commonmark.org/help/ for more information on markdown.
              capcob @BuZz
              @BuZz Sure and thanks for correcting my post.
                barbudreadmon @capcob
                @capcob Hmmmm ok, it seems kinda extreme though, especially since more recent emulators offer improvements that aren't limited to dkong's colors.
                On a sidenote, i believe your code is incomplete, and instructions might have been useful.
                  @barbudreadmon - I have .git patch available should any other 'extremists' want it šŸ˜‚
                    it might have been a good idea to just post a link to that patch then
                      @barbudreadmon - it's something I wanted to share info about, given that mame2003 has not been patched for so long, but like you say maybe not something for which there is much demand.
                      If anyone requests the patch here I'll share it with them.
                      C B 2 Replies Last reply Reply Quote 0
                        capcob @capcob
                        Having said that it should be a trivial exercise for any C developer to substitute the palette values shown above, for those currently calculated in mame 2003.
                          Vintaged cores are meant to be that way
                            mahoneyt944
                            @capcob this is an interesting solution to the issue, as a current maintainer of mame2003-plus, and I suppose mame2003 by proxy, this could certainly be added as an option. Ideally I'd like to backport the proper code making this obsolete but this is a nice way of getting it closer without digging too deep into the code base.
                            I went ahead and posted this in the repository directly, feel free to post your patch there for reference. https://github.com/libretro/mame2003-plus-libretro/issues/1494
                            • RiverstormR
                              Riverstorm
                              @capcob - Any improvements to the old cores are a nice addition. I still use m3plus as one of my staple cores so thanks for this hack, pretty clever idea!
                              • RiverstormR
                                Riverstorm
                                @capcob - Also they are still tweaking, improving and adding games to m3plus so I would add +1 as interested.
                                  barbudreadmon @mahoneyt944
                                  @mahoneyt944 I kinda remember some users mentioning they were using mame2003 because they had a preference for the reddish color, so leaving that core as-is would probably be for the best tbh.
                                  As for mame2003-plus, i opened an issue about that several years ago, with possibly some links that might help backporting this.
                                  M arcadez2003A 2 Replies Last reply Reply Quote 0
                                    mahoneyt944 @barbudreadmon
                                    @barbudreadmon I would only add it as an option to toggle to support both ways for that very reason.
                                      barbudreadmon @Riverstorm
                                      @Riverstorm i'm assuming you are wilstorm from github :
                                      I've always considered you knowledge and suggestions very sound (I still do). I think FBNeo is a fantastic core by all accounts. I'm trying to be objective as I can but I just don't quite understand why the particular stance on this update. Especially a toggle feels a bit over the top but kind of a cool idea for the nostalgic.
                                      I've heard you ask on the RP forums once why would anyone want to use mame2003-plus Donkey Kong when FBNeo has accurate colors. Now mame2003-plus can have those same accurate colors. Ding!? Wouldn't that be a great reason to support your fellow core. Some of the comments through the years on the RP forums you seem to steer folks away from mame2003-plus. To me this and FBNeo are the two best cores for low spec hardware so I support both and use both.
                                      Since the discussion was abruptly locked i'll answer here again : i have always been in favor of mame2003-plus having this fix and even opened an issue about it back in 2018.
                                      On the other side, i still don't think it's right for mame2003, whose incentive is "MAME as it was in 2003", to emulate things differently from how they were back in 2003 without providing a mean to revert to the older behavior, especially since i remember some users giving feedback about prefering the older colors, it should be trivial to turn this into a dipswitch.
                                      Anyway, it was a good lesson, and i won't involve myself anymore with the development of cores that aren't FBNeo.
                                      • RiverstormR
                                        Riverstorm
                                        @barbudreadmon - Looking at the post I believe the Github pull was meant for mame2003-plus and not mame2003.
                                        I think it has been implemented in the more contemporary 2003+ which has lot of updates and left out of vanilla 2003. The best of both worlds…one new core and one old.
                                        ā€œMAME as it was in 2003ā€ā€¦ Is that of core slogan or something?
                                        I think Arcadez split the core [years ago] so as to leave vanilla MAME as isā€¦ā€as it was in 2003ā€ā€¦because of concerns from other members posted in another thread.
                                          @Riverstorm said in Donkey Kong color palette for FBNeo hacked into mame2003-libretro:
                                          This is a PR on mame2003 repo, so it's not about mame2003-plus. I was the one suggesting in this PR that mame2003-plus would be a better candidate for those kind of changes. Again, i was always in favor of this fix being applied to mame2003-plus, and you seem to have a big misunderstanding about that.
                                          It's mame2003's current description.
                                          It was originally meant that way, but apparently that's not the case anymore. The situation with the different mame cores right now seems extremely confusing to me, with mame2003 getting backported fixes that aren't even available in mame2010. Well, i'll update the libretro documentation one last time to make mention of this.
                                          M arcadez2003A 2 Replies Last reply Reply Quote 1
                                            @barbudreadmon i don't understand this notion that mame2003 can't receive updates. This just isn't true. In mame2003, there are restrictions on updates however, updates should not change the romset as to keep the romset static. So a user who has a complete set today will have a set that will always works with mame2003. This still allows for updates which do not effect the rom base. For example, bootstraps to improve game startups, or overflow fixes as to not let the core crash, or in this case a color correction. None in which change the rom base required by the core.
                                            Mame2003-plus however is not static it gets any and all updates in the goal of "making it work". Which means romsets also change.
