    Moved and mounted roms folder to external hard drive and f***** up along the way
    2 Posts 2 Posters 828 Views
    • E
      evilmurray
      Hi again. I have formatted and mounted an external hard drive (vfat) to /home/pi/RetroPie/
      I also moved the contents from RetroPie to the hard drive. But not every directory and file got copied.
      I have no problems re-transfering my roms. But I would very much like to rebuild the roms folder to it´s initial state. Where can I download it? Is there a command for this? Or does anyone have a clean roms folder, that can help me out?
        obsidianspider @evilmurray
        @evilmurray If you do a software update won't it rebuild that directory?
