    Head over Heels from 2003 - Would it work on Retropie?
    head over heelslinux gameretropie port
    29 Posts 5 Posters 1.8k Views
    • duglorD
      duglor @Folly
      @Folly @Lolonois Does this mean it should be/could be/ will be/might be added to anyone who wants it, their pi? or should we/anyone wait for sound improvement or no it should not be used?
      • FollyF
        Folly @duglor
        @duglor
        Not to be rude or anything but all the information is in the posts ;-).
        Summarised (using debian 11 (or 10)):
        • headoverheels doesn't work yet on the pi using allegro4 (starts in menu and can be controlled but has an issue not being able to control/play the game) (sound is ok)
        • headoverheels does work on the a normal x86_64 pc using allegro4 (sound is ok)
        • headoverheels does work on my virtual x86_64 machine using allegro4 (but has issue with sound that does have some hick-ups)
        • @Lolonois is busy trying to update the module-script and use allegro5 and test that (hopefully it will solve the problems and using it could make the game run faster)
        • LolonoisL
          Lolonois @Folly
          @Folly Thanks for validating this. As I learned from your other post the audio issue happens on x64 with liballeg4 and not on arm/Raspberry Pi.
          FollyF LolonoisL 2 Replies Last reply Reply Quote 0
          • FollyF
            Folly @Lolonois
            @Lolonois said in Head over Heels from 2003 - Would it work on Retropie?:
            Right, in a vitual machine x64 only to be correct, a normal x64 pc has no sound issues.
            Btw.
            All above tests have been done with your old module-script using allegro4.
            If you want I can try it on a mac M1 with VMware Debian 11 aarch64 too.
            I just tested your new module-script using Allegro5 and removed the flags so I could install on aarch64, but it doesn't work and hangs with the patch.
            I did not test your new module-script on other computer yet.
            LolonoisL 1 Reply Last reply Reply Quote 0
            • LolonoisL
              Lolonois @Lolonois
              @duglor I would say it is usable and smoothly playable on a Raspberry Pi 4. But keep in mind that a) the scriptmodule is experimental (and the build on arm hardware) and b) the allegro 5 implementation started by Doug Mencken is not optimized.
              @Folly thanks for your summary and testing the different setups.
              FWIW: Optimizing for the Allegro 5 game engine is a major project as the framework concepts have been changed from polling based (allegro 4) to event based (allegro 5). Thus it implies a lot of not only rewriting but also redesign to make a good match to the allegro 5 approach.
              As with any open source project I don't give any statement if/when I will optimize this, but the sources are there for anyone interested and whoever feels to join me (and maybe even has sound allegro5 knowledge) is more than welcome.
              • FollyF
                Folly @Lolonois
                @Lolonois
                Seems quite some work.
                Btw.
                Also tanks for all the work you already did.
                If I could I would help you however, sadly, I do not have the required knowledge.
                • LolonoisL
                  Lolonois @Folly
                  @Folly said in Head over Heels from 2003 - Would it work on Retropie?:
                  Thanks, and no worries. At the moment I did not even consider starting that endeavour.
                  • LolonoisL
                    Lolonois @Folly
                    Hmm. Hangs at the build or hangs on runtime? If it hangs at runtime: Does it also hang without applying the patch (the patch fixes only the flickering first screen when the game starts).
                    • FollyF
                      Folly @Lolonois
                      @Lolonois
                      I didn't describe it very well.
                      Will add a log when I can.
