    Some emulators doesn't work after changes
    retroarchconfig menu
    6 Posts 2 Posters 635 Views
    • F
      FraIgna
      Hello there,
      I have retropie installed and working on this machine:
      Hardware: PC desktop (4gb ram, CPU G2030, Intel Graphics 2500)
      RetroPie Version: 4.8 - x86 - on ubuntu 20.04.4
      USB Devices connected: 1 joypad, mouse, and keyboard
      I had some issues with lr-pcsx-rearmed bios file. I solved them applying the solution suggested in this post:
      https://retropie.org.uk/forum/topic/29004/lr-pcsx-rearmed-not-detecting-bios
      After that, I made some changes to the video settings, in Retroarch menu, in order to get less pixelated PS1 graphics.
      Now the PS1 emulator works fine, however, all other emulators stopped working
      Can anyone give me some hints about how to solve the issues?
      Thank you all!
      • F
        FraIgna @FraIgna
        I tried to update retropie and I got the following message:
        "error running 'git submodule update --init --recursive' - returned 1
        • F
          FraIgna
          trying to solve myself...I cannot open RetroArch from ES menu, so if I launch it from terminal I got the following error:
          :~$ /opt/retropie/emulators/retroarch/bin/retroarch --verbose --menu --config /opt/retropie/configs/all/retroarch.cfg
          [INFO] RetroArch 1.12.0 (Git d6deee4)
          [INFO] CPU Model Name: Intel(R) Pentium(R) CPU G2030 @ 3.00GHz
          [INFO] Funzionalità: MMX MMXEXT SSE SSE2 SSE3 SSE4 SSE4.2
          [INFO] Built: Feb 22 2023
          [INFO] Version: 1.12.0
          [INFO] Git: d6deee4
          [INFO] [Input]: Found input driver: "x".
          [INFO] [Environ]: SET_PIXEL_FORMAT: RGB565.
          [INFO] Cannot resolve save file path.
          [INFO] Cannot resolve save state file path.
          [INFO] [Core]: Versione delle API di libretro: 1, Compilato contro API: 1
          [INFO] [Audio]: Set audio input rate to: 48000.00 Hz.
          [INFO] [Video]: Set video size to: fullscreen.
          Annullato (core dump creato)
            Restore the /opt/retropie/configs/all/retroarch.cfg from the default one (/opt/retropie/configs/all/retroarch.cfg.rp-dist) and try again.
            • F
              FraIgna @mitu
              @mitu thanks...it worked!
              When I launch a PS1 game I get a message on bottom left corner about "override". How I can disable it?
              I suppose this option messes up the onfigurations file for other emulators. Could it be the case?
                mitu Global Moderator @FraIgna
                @FraIgna said in Some emulators doesn't work after changes:
                You go into the overrides menu and delete the override.
                If you saved the override just for that system, it will not affect the other systems/cores. You may have changed a global option (like the video driver) and saved the configuration.
