    Attract Mode issues after updating from source (experimental section)
    attract modevendor idproduct id
    24 Posts 2 Posters 5.3k Views
    • Striderx99S
      Striderx99 @mitu
      @mitu It keeps showing up as a single quote with a space between the two of them inside the .cfg file. That's why I said there was something off with that *** Running line. I hit the tab key, went into the emulator section, found Super Nintendo CD, and made sure to add the single double quote within the args section in "[romfilename]," so it shouldn't do that. I might be wrong, but I think something changed with the re-installation. When I ran the same .cfg file in the past (before the update and re-installation), the SNES CD section of roms loaded without any issues.
        The .cfg file you posted eariler in the topic has two single quotes around [romfilename] and it's not correct. Open the file in an editor, not from AttractMode, and replace them with a double quote.
        Striderx99S 1 Reply Last reply Reply Quote 0
        • Striderx99S
          Striderx99 @mitu
          @mitu I'll try to upload it after I edit it. I'll let you know if it works out. Thanks for your input on this situation.
          • Striderx99S
            Striderx99 @Striderx99
            @Striderx99 It looks like updating the .cfg with those settings and uploading it did the trick. I guess that wraps this issue up. I tested it with three games and they loaded up fine. If anything like this happens with any other emulator, I'll know what to do. Thanks for your patience.
