    Duke nukem 3D problems
    9 Posts 3 Posters 2.7k Views
      gaz1971uk
      Just setting up my system and I've install duke nukem , when I go into ports to run it comes up with sh 1: /home/pi/retropie/roms/ports/duke nukem 3D sh permission denied error, I'm running roms from a usb stick all the other emulators work, but now I'm stuck any help I would be greatful
      • F
        Flynn's
        sudo chmod +x "/home/pi/RetroPie/roms/ports/duke nukem 3D.sh"
          BuZz administrators
          I don't think chmod will help as they have their rom on a non linux filesytem (probably fat32). However updating to the latest retropie should sort it as I added a workaround.
            gaz1971uk
            ive tried both these things and still wont work, none of the games in ports run, same error
              BuZz administrators
              You updated the retropie-setup script and then updated all installed packages ?
                BuZz administrators
                Aah. There will need to be another change actually to work around this. In the meantime you can edit /etc/emulationstation/es_systems.cfg look for the part that says
                  <system>
                    <name>ports</name>
                    <fullname>Ports</fullname>
                    <path>/home/pi/RetroPie/roms/ports</path>
                    <extension>.sh .SH</extension>
                    <command>%ROM%</command>
                    <platform>pc</platform>
                    <theme>ports</theme>
                  </system>
                and replace it with
                  <system>
                    <name>ports</name>
                    <command>bash %ROM%</command>
                  </system>
                  BuZz administrators
                  If you update retropie-setup again, and re-install a port, it should fix it.
                    gaz1971uk
                    thanks for the help
                    it didnt work lol when did it i lost all the emulationstation configurations, so started again and now im just editing the es_systems.cfg file and editing the paths manually, managed to get it working just having trouble with controller now
                      BuZz administrators
                      You incorrectly edited the file then and broke the xml or something. Open a new topic for the controller issue.
