    Xbox Wireless Controller - N64 problems
    2 Posts 2 Posters 781 Views
    • V
      villapanama
      Hey, I am running into some problems hoping someone here can help me.
      I am running 4.0-beta2 version on a Pi 3 B overclocked to 1.4Ghz
      My problem comes with the xbox wireless controllers only while playing n64 games
      I have setup the controllers and they work fine while playing NES and SNES.
      When I try playing a N64 game for some reason controller 1 will not work at all I have to power up both controller and use controller 2
      for N64 I am using mupen64plus-gles2n64
      video CEA-1, all other emulator settings are set to default.
        BuZz administrators
        Please update to the latest RetroPie-Setup - and try removing xboxdrv and instead using the xpad driver (from Packages -> drivers)
