    Who can give me a definitive guide to running ROMs from NAS, spent all day and can't get it to work.....
    helpnasroms dont appeasetup
    9 Posts 3 Posters 4.0k Views
    • I
      icooney
      I have spent the day trying to get my 4.8.0 on RPI 3 to use my NAS to read my ROMs from as I'm fed up of having to copy ones over all the time.
      The issue I face is nothing is shown in the menu, I see no games. It appears to mount and user credentials don't cause any issue.
      I have a Synology NAS with a specific share and specific user for the RetroPie.
      I have tried the official guide: https://retropie.org.uk/docs/Running-ROMs-from-a-Network-Share/
      Didn't work.
      I have tried everything in the discussion linked:
      https://retropie.org.uk/forum/topic/2870/running-roms-from-a-network-share
      Didn't work.
      I have gone round in circles, does anyone have a simple definitive set of instructions that will enable me to setup to run ROMs from my NAS?
      Thanks in advance.
        Please add more info about your setup, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        How did you set-up the mount process - did you use /etc/fstab or you added the mount command before emulationstation starts (in the autostart.sh script) ?
        If user credentials are ok, I assume the listinf of ROMs is also fine - your pi user can list/read the ROM files from the mounted share ?
        I 2 Replies Last reply Reply Quote 0
        • I
          icooney @mitu
          Pi Model 3B+
          Power Supply used: Pi original
          RetroPie Version Used 4.8.0
          Built From: official SD Image on RetroPie website, loaded via Raspberry Pi Imager
          USB Devices connected: none
          Controller used: 8BitDo Pr 2
          Error messages received: None
          Verbose log (if relevant):
          Guide used: (Mention if you followed a guide) Official one mentioned above and then all the suggestions in the forum linked above also
          How to replicate the problem: It is always there as it can't seem to see the ROMs on my NAS.
          • I
            icooney @mitu
            How did you set-up the mount process - did you use /etc/fstab - Yes I tried this second as per the official set up guide
            or you added the mount command before emulationstation starts (in the autostart.sh script) ? - Yes I tried this first as per the official guide
            If user credentials are ok, I assume the listinf of ROMs is also fine - your pi user can list/read the ROM files from the mounted share ? Not sure how I check this, please advise and I can get back t you on this one.
              mitu Global Moderator @icooney
              @icooney said in Who can give me a definitive guide to running ROMs from NAS, spent all day and can't get it to work.....:
              If you browse the /home/pi/RetroPie/roms folder with mc (Midnight Commander) file browser, can you see the ROM folders for each system and the files inside ?
              • retropieuser555R
                retropieuser555
                http://cagewebdev.com/raspberry-pi-connecting-to-a-network-drive/
                There's step here for the fstab option that can be useful:- in terminal sudo mount /home/pi/RetroPie/roms (or whatever folder your mounting the NAS folder into)
                It should give you an error if it's not working using fstab
                Pi 5 4GB
                • I
                  icooney @mitu
                  @mitu said in Who can give me a definitive guide to running ROMs from NAS, spent all day and can't get it to work.....:
                  No I only see the local ROMs folder not the NAS folder
                    Not sure what that means. If you followed the guide(s), the ROMs folder are not 'local' anymore, but their contents are read from the remote NAS server, you wouldn't be able to see the local folders.
                    Can you post the output of the mount command ? Just to check if your ROMs folders are indeed local or remotely mounted from the NAS.
                    • I
                      icooney @mitu
                      Fixed, using MC I could see everything, just my folder structures were wrong and so nothing was showing up, quick rearrangement and it's all good.
                      Thank you for your help.
