    Odd issue running runcommand-onend.sh with if [ -f ..
    pi 5runcommand-onenerror64 bit
    3 Posts 2 Posters 360 Views
    • L
      LeatherWing
      I have two scripts for a dynamic marquee: runcommand-onstart.sh and runcommand-onend.sh
      for debugging I used the statements
      # echo 1 is $1 > ~/runout.txt
      # echo 2 is $2 >> ~/runout.txt
      this works as expected for the onstart.sh. I get a ~/runout.txt file
      however for onend.sh the file created is ~/'runout.txt'$'\r' with the expected contents
      when my script checks for a file
      #!/bin/sh
      DIR="$(dirname "${3}")" ; FILE="$(basename "${3}")"
      GAME=${FILE%.*}
      #IF Maquee exists on RetroPi
      if [ -f $DIR/marquee/$GAME.png ]
      then
      this works fine and as expected in onstart.sh.
      however onend.sh the stops executing at the if statment.
      runcommand.log gives me
      $'\r': command not found (every blank line in the file)
      syntax error: unexpected end of file
      nothing inside or after the if statement will execute.
      For now I'm just setting the dynamic marquee to a default with no logic since it's on exiting a game anyway. However I would like to check if other files are available before setting a static default.
        Check whether the onend script file has the correct line endings, looks like there's a stray DOS CR somewhere.
        • L
          LeatherWing @mitu
          @mitu you're exactly correct. I ran dos2unix on the file and it works as expected. Thought about /r not being a thing in unix files 30 seconds after I posted.
          No clue how it happened, both were edited in notepad++.
