    I2S audio problems on version 4.0
    4 Posts 2 Posters 1.9k Views
      chjensen
      I am having trouble with my external soundcard on version 4.0.
      Everything is working perfect up to version 3.8.1, but when I tried to use version 4.0, the audio stopped working in C64 and MAME games.
      I have configured the audio settings, the same way in both versions.
      The sound card is home made, and is based on the ADAU1761 device from Analog Device.
      I have made my own program to boot the ADAU1761 via I2C, and I can read the correct configuration in the ADAU1761 after boot-up.
      Is anything changed regarding handling an external soundcard? I have discovered, when I’m adding SND_SOC_PCM5102A to the /etc/module file, the audio settings is corrupted somehow. When I write aplay -l to see the sound devices, a lot of errors occurs. This only occur in version 4.0, and not in 3.8.1 or earlier.
      My configuration is:
      Added to /boot/config.txt:
      • dtoverlay=hifiberry-dac
      Enabled in /boot/config.txt:
      • dtparam=i2c_arm=on
      • dtparam=i2s=on
      Added to /etc/modules:
      • snd_soc_pcm5102a
      • snd_soc_hifiberry_dac
      Created /etc/asound.conf:
      pcm.!default {
      type hw
      card 0
      format s16_LE
        BuZz administrators
        The only thing that may have changed to break it that I can think of is the Raspbian Kernel - You could see if downgrading the kernel helps - https://github.com/Hexxeh/rpi-update (and then try and work out at what point it broke - if it is a kernel issue) - you could also update to the latest kernel with that tool to see if it is an issue that has been fixed.
          chjensen
          I found a solution.
          I had to add the following to the /etc/modules
          snd_soc_bcm2708
          bcm2708_dmaengine
          snd_soc_pcm5102a
          BuZzB 1 Reply Last reply Reply Quote 1
            BuZz administrators @chjensen
            @chjensen glad you have it sorted :-)
