    HDMI audio output noisy and distorted
    hmdi audio out
    2 Posts 2 Posters 283 Views
      mr.simonski
      I have a Raspberry Pi CM4 on a Waveshare CM4-Duino with an up
      When my Retropie boots up, the audio is played back by the HDMI audio out. I use a splashscreen video which is played back by omxplayer, using this pcm.card = 0 device by default (HDMI out). The audio via omxplayer sounds fine.
      As soon as Emulationstation starts, the sound gets distorted and noisy. When sound is played for a preview video of a game, the playback sound scratchy and not clear. When I switch to the console and use some speaker-test, the sound is distorted as well:
      speaker-test -t wac -c2 -D hw:0
      When I plug in an USB sound card, the same speaker-test plays fine:
      speaker-test -t wac -c2 -D hw:1
      If I set up the USB sound card to be the default player via /usr/share/alsa/alsa.conf this is fine as well.
      My audio devices:
      $ aplay -l
      **** Liste der Hardware-Geräte (PLAYBACK) ****
      Karte 0: b1 [bcm2835 HDMI 1], Gerät 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
        Sub-Geräte: 8/8
        Sub-Gerät #0: subdevice #0
        Sub-Gerät #1: subdevice #1
        Sub-Gerät #2: subdevice #2
        Sub-Gerät #3: subdevice #3
        Sub-Gerät #4: subdevice #4
        Sub-Gerät #5: subdevice #5
        Sub-Gerät #6: subdevice #6
        Sub-Gerät #7: subdevice #7
      Karte 1: Device [Generic USB Audio Device], Gerät 0: USB Audio [USB Audio]
        Sub-Geräte: 1/1
      $ aplay -L
      null
          Discard all samples (playback) or generate zero samples (capture)
      default:CARD=b1
          bcm2835 HDMI 1, bcm2835 HDMI 1
          Default Audio Device
      sysdefault:CARD=b1
      dmix:CARD=b1,DEV=0
          Direct sample mixing device
      dsnoop:CARD=b1,DEV=0
          Direct sample snooping device
      hw:CARD=b1,DEV=0
          Direct hardware device without any conversions
      plughw:CARD=b1,DEV=0
          Hardware device with all software conversions
      default:CARD=Device
          Generic USB Audio Device, USB Audio
      sysdefault:CARD=Device
      front:CARD=Device,DEV=0
          Front speakers
      surround21:CARD=Device,DEV=0
          2.1 Surround output to Front and Subwoofer speakers
      surround40:CARD=Device,DEV=0
          4.0 Surround output to Front and Rear speakers
      surround41:CARD=Device,DEV=0
          4.1 Surround output to Front, Rear and Subwoofer speakers
      surround50:CARD=Device,DEV=0
          5.0 Surround output to Front, Center and Rear speakers
      surround51:CARD=Device,DEV=0
          5.1 Surround output to Front, Center, Rear and Subwoofer speakers
      surround71:CARD=Device,DEV=0
          7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
      iec958:CARD=Device,DEV=0
          IEC958 (S/PDIF) Digital Audio Output
      dmix:CARD=Device,DEV=0
      dsnoop:CARD=Device,DEV=0
      hw:CARD=Device,DEV=0
      plughw:CARD=Device,DEV=0
      Where could I start to look for a solution?
        dagshocquard @mr.simonski
        @mr-simonski were you able to find a solution to your issue? I have the same issue where the startup audio is perfect but the game selection and in game are distorted to the point of being incomprehensible.
        Any suggestions would be appreciated.
