RetroPie Forum Connection Issues
There seems to be connections issues with the RetroPie Forum servers ever since 2-3 days ago.
I checked my end and it was good, the main site works just fine. (I'm surprised I even managed to write this post!) Is there something going on with the Mythical Beasts hosting service I don't know about or what? -
Not that I know of. When did you have a problem exactly - did you get an error, or just no response ?
I see some errors in the log though related to db - will check.
I have restarted services (hence brief downtime), and am keeping an eye.
Thanks. The problem I was having was that the page sometimes would not load some assets or would not load at all.
Let me know if it's ok now and if you see the problem again.
It is ok now.
I think possibly a nodebb process crashed / broke in a way that it wasn't responding - which means if that process was proxied to by nginx it might sit there doing nothing.
Ok, thanks again for the help!
