    Atari 800 - No Sound on Pi 5
    atari800lr-atari800atari 8bit
    5 Posts 3 Posters 554 Views
    • TPRT
      TPR
      I just did an update of all the main emulator cores and now when I run lr-atari800 I get no sound. I'm assuming this is a bug? Is there a way to revert back to a previous version as I'm pretty sure it worked fine before.
      sugarfreeS 1 Reply Last reply Reply Quote 0
      • sugarfreeS
        sugarfree @TPR
        @TPR It looks like it is an upstream bug: https://github.com/libretro/libretro-atari800/issues/96 with a fix in the works.
        TPRT 1 Reply Last reply Reply Quote 0
        • TPRT
          TPR @sugarfree
          @sugarfree awesome. Thank you. That makes me feel better and worry less! lol
            Try updating RetroPie-Setup and then re-installing the package from source, it should fix the audio volume.
            TPRT 1 Reply Last reply Reply Quote 1
            • TPRT
              TPR @mitu
              @mitu Done and fixed!
