    Wireless Xbox controller and keyboard not working after updating to 4.0
    29 Posts 3 Posters 6.9k Views
      g0nz0uk @BuZz
      @BuZz I'm not sure how to use pastbin to be honest, let me try '''
      This time no controllers work when I boot up today
      pi@retropie:~ $ for js in /dev/input/js*; do echo $js; udevadm info $js; done; dkms status; dmesg; dkms status
      /dev/input/js4
      P: /devices/virtual/input/input6/js4
      N: input/js4
      E: DEVNAME=/dev/input/js4
      E: DEVPATH=/devices/virtual/input/input6/js4
      E: ID_INPUT=1
      E: ID_INPUT_JOYSTICK=1
      E: ID_SERIAL=noserial
      E: MAJOR=13
      E: MINOR=4
      E: SUBSYSTEM=input
      E: TAGS=:seat:uaccess:
      E: USEC_INITIALIZED=321311
      /dev/input/js5
      P: /devices/virtual/input/input7/js5
      N: input/js5
      E: DEVNAME=/dev/input/js5
      E: DEVPATH=/devices/virtual/input/input7/js5
      E: ID_INPUT=1
      E: MAJOR=13
      E: MINOR=5
      E: SUBSYSTEM=input
      E: USEC_INITIALIZED=327974
      -bash: dkms: command not found
      [    0.000000] Booting Linux on physical CPU 0xf00
      [    0.000000] Initializing cgroup subsys cpuset
      [    0.000000] Initializing cgroup subsys cpuacct
      [    0.000000] Linux version 4.4.13-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #894 SMP Mon Jun 13 13:13:27 BST 2016
      [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [    0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
      [    0.000000] cma: Reserved 8 MiB at 0x2e400000
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] On node 0 totalpages: 192512
      [    0.000000] free_area_init_node: node 0, pgdat 808c0e00, node_mem_map add64000
      [    0.000000]   Normal zone: 1692 pages used for memmap
      [    0.000000]   Normal zone: 0 pages reserved
      [    0.000000]   Normal zone: 192512 pages, LIFO batch:31
      [    0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
      [    0.000000] [bcm2709_smp_init_cpus] ncores=4
      [    0.000000] PERCPU: Embedded 13 pages/cpu @aefab000 s22592 r8192 d22464 u53248
      [    0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 190820
      [    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0x68a4212c smsc95xx.macaddr=B8:27:EB:A4:21:2C bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Memory: 744208K/770048K available (6344K kernel code, 432K rwdata, 1712K rodata, 476K init, 764K bss, 17648K reserved, 8192K cma-reserved)
      [    0.000000] Virtual kernel memory layout:
          vector  : 0xffff0000 - 0xffff1000   (   4 kB)
          fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
          vmalloc : 0xaf800000 - 0xff800000   (1280 MB)
          lowmem  : 0x80000000 - 0xaf000000   ( 752 MB)
          modules : 0x7f000000 - 0x80000000   (  16 MB)
            .text : 0x80008000 - 0x807e6470   (8058 kB)
            .init : 0x807e7000 - 0x8085e000   ( 476 kB)
            .data : 0x8085e000 - 0x808ca108   ( 433 kB)
             .bss : 0x808cd000 - 0x8098c1ac   ( 765 kB)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] Hierarchical RCU implementation.
      [    0.000000]  Build-time adjustment of leaf fanout to 32.
      [    0.000000] NR_IRQS:16 nr_irqs:16 16
      [    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
      [    0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
      [    0.000031] Switching to timer-based delay loop, resolution 52ns
      [    0.000346] Console: colour dummy device 80x30
      [    0.001525] console [tty1] enabled
      [    0.001578] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
      [    0.001656] pid_max: default: 32768 minimum: 301
      [    0.002073] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.002123] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.003358] Disabling cpuset control group subsystem
      [    0.003441] Initializing cgroup subsys io
      [    0.003502] Initializing cgroup subsys memory
      [    0.003582] Initializing cgroup subsys devices
      [    0.003635] Initializing cgroup subsys freezer
      [    0.003684] Initializing cgroup subsys net_cls
      [    0.003782] CPU: Testing write buffer coherency: ok
      [    0.003894] ftrace: allocating 21209 entries in 63 pages
      [    0.056340] CPU0: update cpu_capacity 1024
      [    0.056419] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
      [    0.056458] [bcm2709_smp_prepare_cpus] enter
      [    0.056613] Setting up static identity map for 0x8240 - 0x8274
      [    0.059015] [bcm2709_boot_secondary] cpu:1 started (0) 17
      [    0.059447] [bcm2709_secondary_init] enter cpu:1
      [    0.059507] CPU1: update cpu_capacity 1024
      [    0.059515] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
      [    0.060080] [bcm2709_boot_secondary] cpu:2 started (0) 18
      [    0.060437] [bcm2709_secondary_init] enter cpu:2
      [    0.060470] CPU2: update cpu_capacity 1024
      [    0.060478] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
      [    0.061021] [bcm2709_boot_secondary] cpu:3 started (0) 17
      [    0.061276] [bcm2709_secondary_init] enter cpu:3
      [    0.061305] CPU3: update cpu_capacity 1024
      [    0.061313] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
      [    0.061399] Brought up 4 CPUs
      [    0.061510] SMP: Total of 4 processors activated (153.60 BogoMIPS).
      [    0.061543] CPU: All CPU(s) started in HYP mode.
      [    0.061572] CPU: Virtualization extensions available.
      [    0.062502] devtmpfs: initialized
      [    0.074960] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.075467] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.076552] pinctrl core: initialized pinctrl subsystem
      [    0.077374] NET: Registered protocol family 16
      [    0.083220] DMA: preallocated 4096 KiB pool for atomic coherent allocations
      [    0.091592] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.091656] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.091884] Serial: AMBA PL011 UART driver
      [    0.092229] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
      [    0.595195] console [ttyAMA0] enabled
      [    0.599497] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
      [    0.678838] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
      [    0.687556] SCSI subsystem initialized
      [    0.691545] usbcore: registered new interface driver usbfs
      [    0.697186] usbcore: registered new interface driver hub
      [    0.702675] usbcore: registered new device driver usb
      [    0.717846] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-06-20 18:13
      [    0.753647] clocksource: Switched to clocksource arch_sys_counter
      [    0.812780] FS-Cache: Loaded
      [    0.816127] CacheFiles: Loaded
      [    0.835607] NET: Registered protocol family 2
      [    0.841215] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.848483] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
      [    0.855150] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.861668] UDP hash table entries: 512 (order: 2, 16384 bytes)
      [    0.867688] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
      [    0.874409] NET: Registered protocol family 1
      [    0.879255] RPC: Registered named UNIX socket transport module.
      [    0.885244] RPC: Registered udp transport module.
      [    0.889964] RPC: Registered tcp transport module.
      [    0.894701] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.902569] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
      [    0.912471] futex hash table entries: 1024 (order: 4, 65536 bytes)
      [    0.934700] VFS: Disk quotas dquot_6.6.0
      [    0.939020] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.948854] FS-Cache: Netfs 'nfs' registered for caching
      [    0.955389] NFS: Registering the id_resolver key type
      [    0.960515] Key type id_resolver registered
      [    0.964748] Key type id_legacy registered
      [    0.971949] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
      [    0.979616] io scheduler noop registered
      [    0.983570] io scheduler deadline registered (default)
      [    0.988819] io scheduler cfq registered
      [    0.995671] BCM2708FB: allocated DMA memory ee800000
      [    1.000691] BCM2708FB: allocated DMA channel 0 @ f3007000
      [    1.039948] Console: switching to colour frame buffer device 240x67
      [    1.957905] bcm2835-rng 3f104000.rng: hwrng registered
      [    1.963322] vc-cma: Videocore CMA driver
      [    1.967375] vc-cma: vc_cma_base      = 0x00000000
      [    1.972167] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
      [    1.977684] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
      [    1.983517] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
      [    2.013103] brd: module loaded
      [    2.027701] loop: module loaded
      [    2.032116] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
      [    2.040997] Loading iSCSI transport class v2.0-870.
      [    2.046936] usbcore: registered new interface driver smsc95xx
      [    2.052871] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    2.259134] Core Release: 2.80a
      [    2.262353] Setting default values for core params
      [    2.267284] Finished setting default values for core params
      [    2.473393] Using Buffer DMA mode
      [    2.476810] Periodic Transfer Interrupt Enhancement - disabled
      [    2.482741] Multiprocessor Interrupt Enhancement - disabled
      [    2.488431] OTG VER PARAM: 0, OTG VER FLAG: 0
      [    2.492868] Dedicated Tx FIFOs mode
      [    2.496889] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
      [    2.506946] FIQ FSM acceleration enabled for :
      Non-periodic Split Transactions
      Periodic Split Transactions
      High-Speed Isochronous Endpoints
      Interrupt/Control Split Transaction hack enabled
      [    2.529654] dwc_otg: Microframe scheduler enabled
      [    2.529738] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80446a60
      [    2.535765] WARN::hcd_init_fiq:414: FIQ ASM at 0x80446dd0 length 36
      [    2.542140] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaf87e000
      [    2.548320] dwc_otg 3f980000.usb: DWC OTG Controller
      [    2.553414] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
      [    2.560914] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
      [    2.571916] Init: Port Power? op_state=1
      [    2.581185] Init: Power Port (0)
      [    2.590020] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
      [    2.602192] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.614770] usb usb1: Product: DWC OTG Controller
      [    2.624783] usb usb1: Manufacturer: Linux 4.4.13-v7+ dwc_otg_hcd
      [    2.636110] usb usb1: SerialNumber: 3f980000.usb
      [    2.647074] hub 1-0:1.0: USB hub found
      [    2.656148] hub 1-0:1.0: 1 port detected
      [    2.666121] dwc_otg: FIQ enabled
      [    2.666135] dwc_otg: NAK holdoff enabled
      [    2.666145] dwc_otg: FIQ split-transaction FSM enabled
      [    2.666187] Module dwc_common_port init
      [    2.666640] usbcore: registered new interface driver usb-storage
      [    2.678363] mousedev: PS/2 mouse device common for all mice
      [    2.690179] bcm2835-cpufreq: min=600000 max=1000000
      [    2.700790] sdhci: Secure Digital Host Controller Interface driver
      [    2.712317] sdhci: Copyright(c) Pierre Ossman
      [    2.722361] sdhost: log_buf @ ae813000 (ee813000)
      [    2.803693] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
      [    2.834994] sdhci-pltfm: SDHCI platform and OF driver helper
      [    2.846660] ledtrig-cpu: registered to indicate activity on CPUs
      [    2.858146] hidraw: raw HID events driver (C) Jiri Kosina
      [    2.868940] Indeed it is in host mode hprt0 = 00021501
      [    2.894056] usbcore: registered new interface driver usbhid
      [    2.904908] usbhid: USB HID core driver
      [    2.916181] Initializing XFRM netlink socket
      [    2.925949] NET: Registered protocol family 17
      [    2.936030] Key type dns_resolver registered
      [    2.946077] Registering SWP/SWPB emulation handler
      [    2.949241] mmc0: host does not support reading read-only switch, assuming write-enable
      [    2.951150] mmc0: new high speed SDHC card at address 0001
      [    2.952174] mmcblk0: mmc0:0001 00000 29.8 GiB
      [    2.956896]  mmcblk0: p1 p2
      [    2.998907] registered taskstats version 1
      [    3.008565] vc-sm: Videocore shared memory driver
      [    3.018574] [vc_sm_connected_init]: start
      [    3.028682] [vc_sm_connected_init]: end - returning 0
      [    3.039453] of_cfs_init
      [    3.047293] of_cfs_init: OK
      [    3.053707] usb 1-1: new high-speed USB device number 2 using dwc_otg
      [    3.053899] Indeed it is in host mode hprt0 = 00001101
      [    3.091068] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [    3.103702] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [    3.244047] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
      [    3.256176] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    3.269947] hub 1-1:1.0: USB hub found
      [    3.279126] hub 1-1:1.0: 5 ports detected
      [    3.320357] EXT4-fs (mmcblk0p2): recovery complete
      [    3.333253] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [    3.346720] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    3.359655] devtmpfs: mounted
      [    3.368712] Freeing unused kernel memory: 476K (807e7000 - 8085e000)
      [    3.563723] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
      [    3.638574] random: systemd urandom read with 59 bits of entropy available
      [    3.656347] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
      [    3.674155] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
      [    3.674167] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    3.677292] smsc95xx v1.0.4
      [    3.709251] systemd[1]: Detected architecture 'arm'.
      [    3.738072] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a4:21:2c
      [    3.813716] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
      [    3.888968] NET: Registered protocol family 10
      [    3.901464] systemd[1]: Inserted module 'ipv6'
      [    3.915023] systemd[1]: Set hostname to <retropie>.
      [    3.925393] usb 1-1.3: New USB device found, idVendor=7392, idProduct=7811
      [    3.925406] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    3.925415] usb 1-1.3: Product: 802.11n WLAN Adapter
      [    3.925424] usb 1-1.3: Manufacturer: Realtek
      [    3.925433] usb 1-1.3: SerialNumber: 00e04c000001
      [    4.003720] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
      [    4.091259] uart-pl011 3f201000.uart: no DMA platform data
      [    4.138349] usb 1-1.4: New USB device found, idVendor=045e, idProduct=0719
      [    4.151207] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    4.164360] usb 1-1.4: Product: Xbox 360 Wireless Receiver for Windows
      [    4.176702] usb 1-1.4: Manufacturer: ©Microsoft
      [    4.187115] usb 1-1.4: SerialNumber: FE242D50
      [    4.443732] usb 1-1.5: new low-speed USB device number 6 using dwc_otg
      [    4.575899] usb 1-1.5: New USB device found, idVendor=0c40, idProduct=8000
      [    4.588755] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
      [    4.601913] usb 1-1.5: Product: 2.4GHz receiver
      [    4.612268] usb 1-1.5: Manufacturer: ELMCU
      [    4.638537] input: ELMCU 2.4GHz receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:0C40:8000.0001/input/input0
      [    4.677656] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
      [    4.702975] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
      [    4.715154] hid-generic 0003:0C40:8000.0001: input,hidraw0: USB HID v1.11 Keyboard [ELMCU 2.4GHz receiver] on usb-3f980000.usb-1.5/input0
      [    4.734633] input: ELMCU 2.4GHz receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:0C40:8000.0002/input/input1
      [    4.755023] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
      [    4.769284] systemd[1]: Expecting device dev-ttyAMA0.device...
      [    4.784332] hid-generic 0003:0C40:8000.0002: input,hidraw1: USB HID v1.11 Mouse [ELMCU 2.4GHz receiver] on usb-3f980000.usb-1.5/input1
      [    4.808120] systemd[1]: Starting Remote File Systems (Pre).
      [    4.828261] systemd[1]: Reached target Remote File Systems (Pre).
      [    4.841357] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
      [    4.865605] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    4.882140] systemd[1]: Starting Encrypted Volumes.
      [    4.902144] systemd[1]: Reached target Encrypted Volumes.
      [    4.914668] systemd[1]: Starting Swap.
      [    4.933353] systemd[1]: Reached target Swap.
      [    4.944643] systemd[1]: Expecting device dev-mmcblk0p1.device...
      [    4.965532] systemd[1]: Starting Root Slice.
      [    4.984906] systemd[1]: Created slice Root Slice.
      [    4.996639] systemd[1]: Starting User and Session Slice.
      [    5.017065] systemd[1]: Created slice User and Session Slice.
      [    5.029786] systemd[1]: Starting Delayed Shutdown Socket.
      [    5.050146] systemd[1]: Listening on Delayed Shutdown Socket.
      [    5.062731] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
      [    5.083939] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
      [    5.097679] systemd[1]: Starting Journal Socket (/dev/log).
      [    5.117908] systemd[1]: Listening on Journal Socket (/dev/log).
      [    5.130581] systemd[1]: Starting udev Control Socket.
      [    5.149871] systemd[1]: Listening on udev Control Socket.
      [    5.161895] systemd[1]: Starting udev Kernel Socket.
      [    5.181005] systemd[1]: Listening on udev Kernel Socket.
      [    5.192957] systemd[1]: Starting Journal Socket.
      [    5.211740] systemd[1]: Listening on Journal Socket.
      [    5.223356] systemd[1]: Starting System Slice.
      [    5.242092] systemd[1]: Created slice System Slice.
      [    5.253709] systemd[1]: Starting File System Check on Root Device...
      [    5.314576] systemd[1]: Starting system-systemd\x2dfsck.slice.
      [    5.336412] systemd[1]: Created slice system-systemd\x2dfsck.slice.
      [    5.349681] systemd[1]: Starting system-getty.slice.
      [    5.370753] systemd[1]: Created slice system-getty.slice.
      [    5.382942] systemd[1]: Starting system-serial\x2dgetty.slice.
      [    5.403801] systemd[1]: Created slice system-serial\x2dgetty.slice.
      [    5.417035] systemd[1]: Starting Increase datagram queue length...
      [    5.474640] systemd[1]: Starting Restore / save the current clock...
      [    5.505929] systemd[1]: Mounted Huge Pages File System.
      [    5.520819] systemd[1]: Starting Load Kernel Modules...
      [    5.543571] systemd[1]: Starting udev Coldplug all Devices...
      [    5.576619] systemd[1]: Started Set Up Additional Binary Formats.
      [    5.590123] systemd[1]: Starting Create list of required static device nodes for the current kernel...
      [    5.616710] systemd[1]: Mounting POSIX Message Queue File System...
      [    5.641070] systemd[1]: Mounting Debug File System...
      [    5.665167] systemd[1]: Starting LSB: Show custom splashscreen...
      [    5.689564] systemd[1]: Starting Slices.
      [    5.707278] systemd[1]: Reached target Slices.
      [    5.729353] systemd[1]: Mounted Debug File System.
      [    5.747561] systemd[1]: Mounted POSIX Message Queue File System.
      [    5.768917] systemd[1]: Started File System Check on Root Device.
      [    5.808493] systemd[1]: Started Increase datagram queue length.
      [    5.829094] systemd[1]: Started Restore / save the current clock.
      [    5.850000] systemd[1]: Started Load Kernel Modules.
      [    5.924908] systemd[1]: Started Create list of required static device nodes for the current kernel.
      [    5.950649] systemd[1]: Started LSB: Show custom splashscreen.
      [    5.969308] systemd[1]: Time has been changed
      [    6.001616] systemd[1]: Started udev Coldplug all Devices.
      [    6.198933] systemd[1]: Starting Create Static Device Nodes in /dev...
      [    6.254615] systemd[1]: Mounted FUSE Control File System.
      [    6.266615] systemd[1]: Starting Apply Kernel Variables...
      [    6.290219] systemd[1]: Mounting Configuration File System...
      [    6.314167] systemd[1]: Starting Syslog Socket.
      [    6.322684] systemd[1]: Listening on Syslog Socket.
      [    6.322941] systemd[1]: Starting Journal Service...
      [    6.343843] systemd[1]: Started Journal Service.
      [    6.550759] systemd-udevd[142]: starting version 215
      [    6.916575] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
      [    6.917596] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
      [    7.072184] input: Xbox 360 Wireless Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/input/input2
      [    7.074739] input: Xbox 360 Wireless Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.2/input/input3
      [    7.075919] input: Xbox 360 Wireless Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.4/input/input4
      [    7.076966] input: Xbox 360 Wireless Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.6/input/input5
      [    7.077624] usbcore: registered new interface driver xpad
      [    7.358082] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    7.423460] random: nonblocking pool is initialized
      [    7.617726] cfg80211: World regulatory domain updated:
      [    7.617761] cfg80211:  DFS Master region: unset
      [    7.617774] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
      [    7.617793] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
      [    7.617809] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
      [    7.617825] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
      [    7.617898] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
      [    7.617917] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
      [    7.617934] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
      [    7.618032] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
      [    7.618048] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
      [    7.623435] usbcore: registered new interface driver rtl8192cu
      [    7.938267] systemd-journald[141]: Received request to flush runtime journal from PID 1
      [    8.959677] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      [    9.639528] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:2359296k SSFS
      [   10.126909] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
      [   10.127234] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
      [   10.888802] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      [   10.916477] cfg80211: Regulatory domain changed to country: GB
      [   10.916514] cfg80211:  DFS Master region: ETSI
      [   10.916526] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
      [   10.916546] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
      [   10.916565] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
      [   10.916585] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
      [   10.916602] cfg80211:   (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
      [   10.916617] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
      [   11.594249] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   11.595350] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
      [   17.543219] input: Xbox Gamepad (userspace driver) as /devices/virtual/input/input6
      [   17.544774] input: Xbox Gamepad (userspace driver) #2 as /devices/virtual/input/input7
        BuZz administrators
        Backticks not apostrophes. See http://commonmark.org/help/.
          BuZz administrators
          You are still using the xboxdrv - not the updated xpad driver as I asked in my first reply. https://retropie.org.uk/forum/post/22112
          you need to remove xboxdrv from Manage Packages -> drivers and install the updated xpad driver.
            g0nz0uk @BuZz
            @BuZz I did that not sure why it keep returning
            This is a fresh 4.0.1 install and both work
            /dev/input/js0
            P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0079:0006.0001/input/input0/js0
            N: input/js0
            S: input/by-id/usb-DragonRise_Inc._Generic_USB_Joystick-joystick
            S: input/by-path/platform-3f980000.usb-usb-0:1.2:1.0-joystick
            E: DEVLINKS=/dev/input/by-id/usb-DragonRise_Inc._Generic_USB_Joystick-joystick /dev/input/by-path/platform-3f980000.usb-usb-0:1.2:1.0-joystick
            E: DEVNAME=/dev/input/js0
            E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0079:0006.0001/input/input0/js0
            E: ID_BUS=usb
            E: ID_FOR_SEAT=input-platform-3f980000_usb-usb-0_1_2_1_0
            E: ID_INPUT=1
            E: ID_MODEL=Generic_USB_Joystick
            E: ID_MODEL_ENC=Generic\x20\x20\x20USB\x20\x20Joystick\x20\x20
            E: ID_MODEL_ID=0006
            E: ID_PATH=platform-3f980000.usb-usb-0:1.2:1.0
            E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_2_1_0
            E: ID_REVISION=0107
            E: ID_SERIAL=DragonRise_Inc._Generic_USB_Joystick
            E: ID_TYPE=hid
            E: ID_USB_DRIVER=usbhid
            E: ID_USB_INTERFACES=:030000:
            E: ID_USB_INTERFACE_NUM=00
            E: ID_VENDOR=DragonRise_Inc.
            E: ID_VENDOR_ENC=DragonRise\x20Inc.\x20\x20
            E: ID_VENDOR_ID=0079
            E: MAJOR=13
            E: MINOR=0
            E: SUBSYSTEM=input
            E: USEC_INITIALIZED=26842
            /dev/input/js1
            P: /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:0079:0006.0002/input/input1/js1
            N: input/js1
            S: input/by-path/platform-3f980000.usb-usb-0:1.4:1.0-joystick
            E: DEVLINKS=/dev/input/by-id/usb-DragonRise_Inc._Generic_USB_Joystick-joystick /dev/input/by-path/platform-3f980000.usb-usb-0:1.4:1.0-joystick
            E: DEVNAME=/dev/input/js1
            E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:0079:0006.0002/input/input1/js1
            E: ID_BUS=usb
            E: ID_FOR_SEAT=input-platform-3f980000_usb-usb-0_1_4_1_0
            E: ID_INPUT=1
            E: ID_MODEL_ID=0006
            E: ID_PATH=platform-3f980000.usb-usb-0:1.4:1.0
            E: ID_PATH_TAG=platform-3f980000_usb-usb-0_1_4_1_0
            E: ID_REVISION=0107
            E: ID_TYPE=hid
            E: MAJOR=13
            E: MINOR=1
            E: SUBSYSTEM=input
            E: USEC_INITIALIZED=28964
            /dev/input/js2
            P: /devices/virtual/input/input2/js2
            N: input/js2
            E: DEVNAME=/dev/input/js2
            E: DEVPATH=/devices/virtual/input/input2/js2
            E: ID_INPUT=1
            E: MAJOR=13
            E: MINOR=2
            E: SUBSYSTEM=input
            E: USEC_INITIALIZED=522398
            /dev/input/js3
            P: /devices/virtual/input/input3/js3
            N: input/js3
            E: DEVNAME=/dev/input/js3
            E: DEVPATH=/devices/virtual/input/input3/js3
            E: ID_INPUT=1
            E: MAJOR=13
            E: MINOR=3
            E: SUBSYSTEM=input
            E: USEC_INITIALIZED=523461
            [    0.000000] Booting Linux on physical CPU 0x0
            [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
            [    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
            [    0.000000] PERCPU: Embedded 13 pages/cpu @aefaa000 s22592 r8192 d22464 u53248
            [    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1600 bcm2708_fb.fbheight=1200 bcm2709.boardrev=0xa02082 bcm2709.serial=0x610c0ec9 smsc95xx.macaddr=B8:27:EB:0C:0E:C9 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet loglevel=3 consoleblank=0
            [    0.000000] Memory: 744204K/770048K available (6344K kernel code, 432K rwdata, 1712K rodata, 476K init, 764K bss, 17652K reserved, 8192K cma-reserved)
            [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
            [    0.000024] Switching to timer-based delay loop, resolution 52ns
            [    0.000275] Console: colour dummy device 80x30
            [    0.000474] console [tty1] enabled
            [    0.000497] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
            [    0.000516] pid_max: default: 32768 minimum: 301
            [    0.000831] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
            [    0.000845] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
            [    0.001777] Disabling cpuset control group subsystem
            [    0.001809] Initializing cgroup subsys io
            [    0.001837] Initializing cgroup subsys memory
            [    0.001875] Initializing cgroup subsys devices
            [    0.001895] Initializing cgroup subsys freezer
            [    0.001916] Initializing cgroup subsys net_cls
            [    0.001965] CPU: Testing write buffer coherency: ok
            [    0.002030] ftrace: allocating 21209 entries in 63 pages
            [    0.052435] CPU0: update cpu_capacity 1024
            [    0.052467] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
            [    0.052479] [bcm2709_smp_prepare_cpus] enter
            [    0.052611] Setting up static identity map for 0x8240 - 0x8274
            [    0.054254] [bcm2709_boot_secondary] cpu:1 started (0) 17
            [    0.054614] [bcm2709_secondary_init] enter cpu:1
            [    0.054657] CPU1: update cpu_capacity 1024
            [    0.054664] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
            [    0.055037] [bcm2709_boot_secondary] cpu:2 started (0) 17
            [    0.055299] [bcm2709_secondary_init] enter cpu:2
            [    0.055320] CPU2: update cpu_capacity 1024
            [    0.055326] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
            [    0.055683] [bcm2709_boot_secondary] cpu:3 started (0) 17
            [    0.055864] [bcm2709_secondary_init] enter cpu:3
            [    0.055885] CPU3: update cpu_capacity 1024
            [    0.055891] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
            [    0.055951] Brought up 4 CPUs
            [    0.055974] SMP: Total of 4 processors activated (153.60 BogoMIPS).
            [    0.055982] CPU: All CPU(s) started in HYP mode.
            [    0.055989] CPU: Virtualization extensions available.
            [    0.056598] devtmpfs: initialized
            [    0.066803] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
            [    0.067121] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
            [    0.067821] pinctrl core: initialized pinctrl subsystem
            [    0.068352] NET: Registered protocol family 16
            [    0.073581] DMA: preallocated 4096 KiB pool for atomic coherent allocations
            [    0.080485] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
            [    0.080496] hw-breakpoint: maximum watchpoint size is 8 bytes.
            [    0.080654] Serial: AMBA PL011 UART driver
            [    0.080793] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
            [    0.080955] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
            [    0.144566] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
            [    0.145126] SCSI subsystem initialized
            [    0.145302] usbcore: registered new interface driver usbfs
            [    0.145389] usbcore: registered new interface driver hub
            [    0.145485] usbcore: registered new device driver usb
            [    0.151995] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-06-20 18:13
            [    0.179236] clocksource: Switched to clocksource arch_sys_counter
            [    0.223990] FS-Cache: Loaded
            [    0.224256] CacheFiles: Loaded
            [    0.236534] NET: Registered protocol family 2
            [    0.237381] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
            [    0.237494] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
            [    0.237683] TCP: Hash tables configured (established 8192 bind 8192)
            [    0.237775] UDP hash table entries: 512 (order: 2, 16384 bytes)
            [    0.237821] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
            [    0.238050] NET: Registered protocol family 1
            [    0.238360] RPC: Registered named UNIX socket transport module.
            [    0.238370] RPC: Registered udp transport module.
            [    0.238378] RPC: Registered tcp transport module.
            [    0.238386] RPC: Registered tcp NFSv4.1 backchannel transport module.
            [    0.239522] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
            [    0.240819] futex hash table entries: 1024 (order: 4, 65536 bytes)
            [    0.254091] VFS: Disk quotas dquot_6.6.0
            [    0.254402] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
            [    0.256680] FS-Cache: Netfs 'nfs' registered for caching
            [    0.257570] NFS: Registering the id_resolver key type
            [    0.257612] Key type id_resolver registered
            [    0.257621] Key type id_legacy registered
            [    0.259958] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
            [    0.260089] io scheduler noop registered
            [    0.260109] io scheduler deadline registered (default)
            [    0.260162] io scheduler cfq registered
            [    0.262669] BCM2708FB: allocated DMA memory ee800000
            [    0.262695] BCM2708FB: allocated DMA channel 0 @ f3007000
            [    0.291120] Console: switching to colour frame buffer device 200x75
            [    1.169460] bcm2835-rng 3f104000.rng: hwrng registered
            [    1.169645] vc-cma: Videocore CMA driver
            [    1.169656] vc-cma: vc_cma_base      = 0x00000000
            [    1.169665] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
            [    1.169674] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
            [    1.169963] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
            [    1.184762] brd: module loaded
            [    1.193423] loop: module loaded
            [    1.194347] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
            [    1.195805] Loading iSCSI transport class v2.0-870.
            [    1.196447] usbcore: registered new interface driver smsc95xx
            [    1.196498] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
            [    1.396733] Core Release: 2.80a
            [    1.396747] Setting default values for core params
            [    1.396780] Finished setting default values for core params
            [    1.597146] Using Buffer DMA mode
            [    1.597156] Periodic Transfer Interrupt Enhancement - disabled
            [    1.597165] Multiprocessor Interrupt Enhancement - disabled
            [    1.597174] OTG VER PARAM: 0, OTG VER FLAG: 0
            [    1.597188] Dedicated Tx FIFOs mode
            [    1.597503] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
            [    1.597534] FIQ FSM acceleration enabled for :
            [    1.597557] dwc_otg: Microframe scheduler enabled
            [    1.597602] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80446a60
            [    1.597615] WARN::hcd_init_fiq:414: FIQ ASM at 0x80446dd0 length 36
            [    1.597630] WARN::hcd_init_fiq:439: MPHI regs_base at 0xafc46000
            [    1.597690] dwc_otg 3f980000.usb: DWC OTG Controller
            [    1.597726] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
            [    1.597761] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
            [    1.597811] Init: Port Power? op_state=1
            [    1.597819] Init: Power Port (0)
            [    1.598020] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
            [    1.598035] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
            [    1.598048] usb usb1: Product: DWC OTG Controller
            [    1.598060] usb usb1: Manufacturer: Linux 4.4.13-v7+ dwc_otg_hcd
            [    1.598072] usb usb1: SerialNumber: 3f980000.usb
            [    1.598848] hub 1-0:1.0: USB hub found
            [    1.598890] hub 1-0:1.0: 1 port detected
            [    1.599520] dwc_otg: FIQ enabled
            [    1.599530] dwc_otg: NAK holdoff enabled
            [    1.599538] dwc_otg: FIQ split-transaction FSM enabled
            [    1.599568] Module dwc_common_port init
            [    1.599815] usbcore: registered new interface driver usb-storage
            [    1.600070] mousedev: PS/2 mouse device common for all mice
            [    1.600766] bcm2835-cpufreq: min=600000 max=1350000
            [    1.601067] sdhci: Secure Digital Host Controller Interface driver
            [    1.601075] sdhci: Copyright(c) Pierre Ossman
            [    1.601371] sdhost: log_buf @ ae813000 (ee813000)
            [    1.679265] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
            [    1.681508] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
            [    1.681522] mmc-bcm2835 3f300000.mmc: DMA channel allocated
            [    1.736092] mmc0: host does not support reading read-only switch, assuming write-enable
            [    1.737933] mmc0: new high speed SDXC card at address 0001
            [    1.738518] mmcblk0: mmc0:0001 00000 59.6 GiB
            [    1.739366] sdhci-pltfm: SDHCI platform and OF driver helper
            [    1.739792] ledtrig-cpu: registered to indicate activity on CPUs
            [    1.739908] hidraw: raw HID events driver (C) Jiri Kosina
            [    1.740087] usbcore: registered new interface driver usbhid
            [    1.740095] usbhid: USB HID core driver
            [    1.740634] Initializing XFRM netlink socket
            [    1.740668] NET: Registered protocol family 17
            [    1.740798] Key type dns_resolver registered
            [    1.741033]  mmcblk0: p1 p2
            [    1.741383] Registering SWP/SWPB emulation handler
            [    1.742239] registered taskstats version 1
            [    1.742426] vc-sm: Videocore shared memory driver
            [    1.742441] [vc_sm_connected_init]: start
            [    1.742929] [vc_sm_connected_init]: end - returning 0
            [    1.745130] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
            [    1.745488] of_cfs_init
            [    1.745565] of_cfs_init: OK
            [    1.752195] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [    1.752210] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [    1.758542] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
            [    1.760098] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [    1.761645] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
            [    1.764426] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
            [    1.789374] Indeed it is in host mode hprt0 = 00021501
            [    1.855151] mmc1: new high speed SDIO card at address 0001
            [    1.969269] usb 1-1: new high-speed USB device number 2 using dwc_otg
            [    1.969399] Indeed it is in host mode hprt0 = 00001101
            [    2.169529] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
            [    2.169545] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
            [    2.170275] hub 1-1:1.0: USB hub found
            [    2.170378] hub 1-1:1.0: 5 ports detected
            [    2.225371] EXT4-fs (mmcblk0p2): recovery complete
            [    2.246538] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [    2.246593] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [    2.247197] devtmpfs: mounted
            [    2.247942] Freeing unused kernel memory: 476K (807e7000 - 8085e000)
            [    2.449287] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
            [    2.465713] random: systemd urandom read with 69 bits of entropy available
            [    2.549548] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
            [    2.549570] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
            [    2.552439] smsc95xx v1.0.4
            [    2.579628] NET: Registered protocol family 10
            [    2.612905] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:0c:0e:c9
            [    2.689341] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
            [    2.794744] usb 1-1.2: New USB device found, idVendor=0079, idProduct=0006
            [    2.794767] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
            [    2.794780] usb 1-1.2: Product: Generic   USB  Joystick
            [    2.794792] usb 1-1.2: Manufacturer: DragonRise Inc.
            [    2.879298] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
            [    2.985267] usb 1-1.4: New USB device found, idVendor=0079, idProduct=0006
            [    2.985288] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
            [    2.985301] usb 1-1.4: Product: Generic   USB  Joystick
            [    2.985313] usb 1-1.4: Manufacturer: DragonRise Inc.
            [    3.064353] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
            [    3.255981] fuse init (API version 7.23)
            [    3.677045] systemd-udevd[145]: starting version 215
            [    3.889054] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
            [    3.893626] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
            [    4.055695] input: DragonRise Inc.   Generic   USB  Joystick   as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0079:0006.0001/input/input0
            [    4.056205] dragonrise 0003:0079:0006.0001: input,hidraw0: USB HID v1.10 Joystick [DragonRise Inc.   Generic   USB  Joystick  ] on usb-3f980000.usb-1.2/input0
            [    4.057872] input: DragonRise Inc.   Generic   USB  Joystick   as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:0079:0006.0002/input/input1
            [    4.058318] dragonrise 0003:0079:0006.0002: input,hidraw1: USB HID v1.10 Joystick [DragonRise Inc.   Generic   USB  Joystick  ] on usb-3f980000.usb-1.4/input0
            [    4.216513] usbcore: registered new interface driver brcmfmac
            [    4.319597] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            [    4.360105] random: nonblocking pool is initialized
            [    4.391265] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
            [    4.417745] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
            [    4.477333] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
            [    4.477365] cfg80211: World regulatory domain updated:
            [    4.477374] cfg80211:  DFS Master region: unset
            [    4.477385] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
            [    4.477399] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
            [    4.477411] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
            [    4.477423] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
            [    4.477439] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
            [    4.477453] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
            [    4.477465] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
            [    4.477477] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
            [    4.477490] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
            [    4.698267] systemd-journald[125]: Received request to flush runtime journal from PID 1
            [    5.019028] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
            [    5.019058] brcmfmac: brcmf_add_if: ignore IF event
            [    5.024180] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
            [    5.024236] brcmfmac: power management disabled
            [    6.062064] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:114688k SSFS
            [    6.210704] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
            [    6.210870] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
            [    6.582120] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
            [    6.606731] cfg80211: Regulatory domain changed to country: GB
            [    6.606744] cfg80211:  DFS Master region: ETSI
            [    6.606748] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
            [    6.606755] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
            [    6.606762] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
            [    6.606768] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
            [    6.606774] cfg80211:   (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
            [    6.606779] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
            [   20.550806] input: Xbox Gamepad (userspace driver) as /devices/virtual/input/input2
            [   20.552004] input: Xbox Gamepad (userspace driver) #2 as /devices/virtual/input/input3
              BuZz administrators
              You can't have as you still had xboxdrv enabled, and you didn't have dkms installed which is required/installed by the updated xpad driver.
                BuZz administrators
                I thought you had an xbox wireless controller or do you have some clones ? As they are identified as "DragonRise_Inc._Generic_USB_Joystick-joystick"
                G 2 Replies Last reply Reply Quote 0
                  g0nz0uk @BuZz
                  @BuZz Think I'm being think and actually misread you first post. I have offical Xbox controllers, so I've removed the Xboxdrv drivers and install xpad drivers.
                  The "DragonRise_Inc._Generic_USB_Joystick-joystick" are off my other system which is a bartop, this SD card was used in that a while back (3.6).
                    BuZz administrators
                    I'm confused - you just ran those commands on a working system ? The commands I got you to write show me what is currently connected - and it shows me no XBOX joysticks. Just DragonRise_Inc._Generic_USB_Joystick-joystick - I wanted those commands run on the system with the non working xbox controllers.
                      g0nz0uk @BuZz
                      @BuZz All is working now, "should of gone to Specsavers".
                      My apologies @BuZz wasted your time :(
