    Audio issue HDMI
    audiohdmi audiopi5
    8 Posts 2 Posters 1.2k Views
      dvojkaa
      Pi Model: 5
      Power Supply used: Original
      RetroPie Version Used : 4.8.8
      Built From: On top of Raspi OS 64bit Lite
      USB Devices connected: Keyboard
      Error messages received: VolumeControl::init() - Failed to find mixer elements!
      Attachment of config files: (Fresh from install and I have tried adding hdmi_driver=2 and hdmi_force_hotplug=1)
      How to replicate the problem: Fresh install on rpi 5 8gb and no sound. I tried so many mitu advice's and others on ytb but nothing worked for me. Once it worked on really old TV but since them atleast 4 monitor/TV did not beep at me.
      Does anyone know how to fix it ? Thanks
      • sugarfreeS
        sugarfree
        Audio doesn't work by default in the current stage of RetroPie development.
        You have to manually set the audio output to HDMI
        by going to RetroPie Setup > Audio > HDMI.Then restart EmulationStation.
        If this doesn't work, then I believe something else is happening.
          dvojkaa @sugarfree
          @sugarfree Nope this doesn't work ://
          sugarfreeS 1 Reply Last reply Reply Quote 0
          • sugarfreeS
            sugarfree @dvojkaa
            @dvojkaa I have uploaded my backup image of RPi5. It's an unofficial, 100% clean image (with no BIOS/ROMs files) of RetroPie. I followed the official guide to install it. Can you please try with this image?
            https://retropie.org.uk/forum/post/298705
              dvojkaa @sugarfree
              @sugarfree
              i have tried it with yoir image ane i have no words it worked once when my friend was over but since then nothing.
              • sugarfreeS
                sugarfree @dvojkaa
                @dvojkaa
                Try to set the audio again and restart the system :
                RetroPie-Setup -> audio -> Hdmi
                Did you have install the Desktop ?
                  dvojkaa @sugarfree
                  @sugarfree yes i tried lite version and normal full and restarting never helped
                    dvojkaa @dvojkaa
                    @dvojkaa for others there is this topic
                    https://retropie.org.uk/forum/topic/35350/no-audio-on-raspberry-pi-5/8
                    and it seems to work for him so i will try the same a write here again what happes
