    problems after using Rp manager
    5 Posts 3 Posters 2.0k Views
      edmaul69
      So my first shader i did was for the psx without the manager and it had scanlines (first a tv then without) so now that i installed the manager and tested several shaders and overlays i decided what i wanted now several emulators including the psx have options set for overlays and they do not work at all. I am on pi3 with rp 4.0.1
      Edit: nm if it isnt working you have to close the rp manager in putty
      • FloobF
        Floob
        Please give details:
        If you mean you installed this, please say which version, and which options you selected:
        https://github.com/biscuits99/rp-video-manager
          edmaul69 @Floob
          @Floob im good. i had to exit out of putty which was running rp manager to fix it.
          i dont know who uploads the pics on github, but the chito gamegear overlay had a ton of "dead pixels"on the screen. i fixed it up if you or anyone else are interested.
          undefined
            Chito
            @edmaul69 they are not dead pixels... it's an effect in the overlay to simulate the what the actual LCD screen did on the game gear. kinda like scanlines
              edmaul69 @Chito
              @Chito It wasnt the lines that was a problem. If i remember correctly there was like 3 solid colored pixels that made it appears as dead pixels. Been awhile so i cant be 100% positive. However, i love your overlays. Really nice work. Thank you for making them for us enjoy.
