    8bitdo Zero Gamepad mapping problem
    8bitdo
    23 Posts 4 Posters 12.8k Views
    • FloobF
      Floob
      @frudda You can set video output using the configuration editor.
      https://github.com/retropie/retropie-setup/wiki/Configuration-Editor
      • F
        frudda
        retroarch.cfg is now back to normal and full screen changed in configuration editor
        I added
        input_player1_joypad_index = "0"
        input_player2_joypad_index = "1"
        in retroarch.cfg
        they are removed in controller cfg
        I also removed the detected from boot on bluetooth.
        I start the NES 30 Pro first
        after Zero Gamepad.
        In Nes its working controller 2 now if i check retroarch input2 in Nes game. The input is declared. but wonder if its my old settings here
        Because if I switch to snes and play controller 2. All buttons is not working and have wrong buttons on input2 declared
        Now both controllers are detected as port #1
        • F
          frudda
          Changed
          input_driver = "udev"
          To
          input_driver = "sdl"
          On configs including controller cfg, now it works!
          The retroarch on "udev" reconfigure the controller i guess to wrong mapping?
          Found this post
          https://retropie.org.uk/forum/topic/192/8bitdo-fc30-pro-works-in-es-but-not-retroarch/14
          Thanks to everybody
