    i2S Audio issues retropie using adafruit class D-DAc and amplifier
    i2sampaudiocodeconfighelp
    4 Posts 2 Posters 371 Views
      arvis1
      Hello! I am running into issues when setting up i2s audio using the following guide:
      https://cdn-learn.adafruit.com/downloads/pdf/adafruit-max98357-i2s-class-d-mono-amp.pdf
      I can get the sound to play when using speaker-test c2, but only on "Right" and not at all in retropie/emulationStation.
      RPi 4B
      Pisugar S Plus
      Made from official Rpi imager, retropie V. 4.8
        Did you disable the onboard audio on the Pi ? What's the output of
        aplay -l
        aplay -L
        amixer
          arvis1 @mitu
          pi@retropie:~ $ aplay -l
          card 0: MAX98357A [MAX98357A], device 0: bcm2835-i2s-HiFi HiFi-0 [bcm2835-i2s-HiFi HiFi-0]
            Subdevices: 0/1
            Subdevice #0: subdevice #0
          pi@retropie:~ $ aplay -L
          null
              Discard all samples (playback) or generate zero samples (capture)
          jack
              JACK Audio Connection Kit
          pulse
              PulseAudio Sound Server
          speakerbonnet
          dmixer
          softvol
          default
          sysdefault:CARD=MAX98357A
              MAX98357A, bcm2835-i2s-HiFi HiFi-0
              Default Audio Device
          dmix:CARD=MAX98357A,DEV=0
              Direct sample mixing device
          dsnoop:CARD=MAX98357A,DEV=0
              Direct sample snooping device
          hw:CARD=MAX98357A,DEV=0
              Direct hardware device without any conversions
          plughw:CARD=MAX98357A,DEV=0
              Hardware device with all software conversions
          usbstream:CARD=MAX98357A
              MAX98357A
              USB Stream Output
          pi@retropie:~ $ amixer
          Simple mixer control 'PCM',0
            Capabilities: volume
            Playback channels: Front Left - Front Right
            Capture channels: Front Left - Front Right
            Limits: 0 - 255
            Front Left: 204 [80%]
            Front Right: 204 [80%]
          I think i disabled the onboard audio, where is that? I'll add my asound.conf file here as well. Thank you for the help! I realised that pulseaudio for some reason is still mentioned here, even though i uninstalled that or i thought i did. I added the asound.conf file as well.
          pcm.speakerbonnet {
             type hw card 0
          pcm.dmixer {
             type dmix
             ipc_key 1024
             ipc_perm 0666
             slave {
               pcm "speakerbonnet"
               period_time 0
               period_size 1024
               buffer_size 8192
               rate 44100
               channels 2
          ctl.dmixer {
              type hw card 0
          pcm.softvol {
              type softvol
              slave.pcm "dmixer"
              control.name "PCM"
              control.card 0
          ctl.softvol {
           type hw card 0
          pcm.!default {
              type             plug
              slave.pcm       "softvol"
            arvis1 @arvis1
            @arvis1 NEVERMIND, i found the issue. In this thread: https://retropie.org.uk/forum/topic/34661/solved-remove-pulseaudio-and-revert-back-to-alsa/3
            The issue was that using purge on pulseaudio did not fully uninstall, so you have to go into the retropie setup as detailed in this guide.
