    PSP games doesn't work due to ppsspp and lr-ppsspp crashing on load
    ppsspplr-ppsspp crashlr-ppsspp
    16 Posts 4 Posters 2.8k Views
      ploinkploink
      When I try to load a game in either emulator it crashes with the following message:
      (/home/pi/RetroPie-Setup/tmp/build/lr-ppsspp/ppsspp/Common/ArmEmitter.cpp:VMOV:1692) Critical: [cpu_info.bVFP | cpu_info.bNEON] VMOV_neon requires VFP or NEON
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 1328:   993 Trace/breakpoint trap   /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-ppsspp/ppsspp_libretro.so --config /opt/retropie/configs/psp/retroarch.cfg "/home/pi/RetroPie/roms/psp/Chili Con Carnage.cso" --appendconfig /dev/shm/retroarch.cfg
      I tried to install both from source but got the same error..
      I'm running retropie 4.8.9 (Raspbian GNU/Linux 10 (buster)) on a raspberry pi 4
      If I launch the game with ppsspp it manages get as far as the in game loading screen before it crashes out, with lr-ppsspp then it crashes before then.
      After a crash then I also cannot switch default emulator without rebooting, since it still crashes even though it loads the "set default emulator" menu.
      ppsspp is built from latest source (branch: v1.13.2)
      lr-ppsspp is built from latest source (branch: v1.13.2)
        mitu Global Moderator @ploinkploink
        @ploinkploink said in PSP games doesn't work due to ppsspp and lr-ppsspp crashing on load:
        RetroPie installs an older version and not the latest source - did just manually modify the installation script to get a newer version or compiled it separately ?
        EDI:T actually 1.13.2 is right, sorry . Do you get the crash with all the PSP games or just with some of the games ?
        Please provide also the rest of the info requested in https://retropie.org.uk/forum/topic/3/read-this-first.
        • sugarfreeS
          sugarfree
          It looks like your game is compressed (.cso). This version of PPSSPP (v13.2) doesn't support CSO files. You have to modify the script to build a newer version or wait until the developers update the emulator.
            ploinkploink @mitu
            Thank you for the fast reply! <3
            I have tried with 6 different games all with the same result.
            I tried with the preinstalled (from binary) ppsspp first, when that failed I updated the setup script and tried to install lr-ppsspp from binary. After that I removed both and installed them from source.
            Here is the rest of the info:
            Pi Model: rpi4
            Power Supply used: original rpi branded power supply
            RetroPie Version Used: 4.8.9
            Built From: pre made image from retropie website (retropie-buster-4.8-rpi4_400.img.gz)
            USB Devices connected: Logitech keyboard and mouse (disconnected), external harddrive containing roms
            Controller used: PS3 controller
            Error messages received:
            Guide used: didn't follow a specific guide apart from standard instruction from the retropie website (copy roms to the correct folder and install the emulators)
            File: '/media/usb0/retropie-mount/roms/psp/Chili Con Carnage.cso'
            Emulator: ppsspp, lr-ppsspp
            Attachment of config files:
            /opt/retropie/configs/psp/emulator.cfg
            ppsspp = "pushd /opt/retropie/emulators/ppsspp; /opt/retropie/emulators/ppsspp/PPSSPPSDL --fullscreen %ROM%; popd"
            lr-ppsspp = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-ppsspp/ppsspp_libretro.so --config /opt/retropie/configs/psp/retroarch.cfg %ROM%"
            default = "lr-ppsspp"
            input_remapping_directory = "/opt/retropie/configs/psp"
            savefile_directory = /home/pi/.config/ppsspp
              ploinkploink @sugarfree
              @sugarfree said in PSP games doesn't work due to ppsspp and lr-ppsspp crashing on load:
              Aaaah ok yeah I compressed the iso files to save some space
              it said on the retropie website it was supported but didn't mention specific versions.
              Thank you!
              Is there a recommended version that's best to use with cso files or just the newest?
              sugarfreeS 1 Reply Last reply Reply Quote 0
              • sugarfreeS
                sugarfree @ploinkploink
                @ploinkploink Sorry, I was wrong! I confused it with the .chd file format that was added recently.
                I suggest testing the .iso to see if it is running correctly.
                  @sugarfree No worries! Too bad hehehe would have been an easy fix :)
                    ploinkploink @ploinkploink
                    here is what it says in es_log.txt after attempting to run the game:
                    Jan 31 15:34:18 lvl2:   Attempting to launch game...
                    Jan 31 15:34:19 lvl2:           /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ psp /home/pi/RetroPie/roms/psp/Chili\ Con\ Carnage.cso
                    Jan 31 15:34:24 lvl2:   Creating window...
                    Jan 31 15:34:25 lvl2:   Created window successfully.
                    Jan 31 15:34:25 lvl2:   GL vendor:   Broadcom
                    Jan 31 15:34:25 lvl2:   GL renderer: V3D 4.2
                    Jan 31 15:34:25 lvl2:   GL version:  2.1 Mesa 19.3.2
                    Jan 31 15:34:25 lvl2:   Checking available OpenGL extensions...
                    Jan 31 15:34:25 lvl2:    ARB_texture_non_power_of_two: ok
                    Jan 31 15:34:25 lvl2:   Added known joystick Sony PLAYSTATION(R)3 Controller (instance ID: 1, device index: 0)
                      What error do you get with ppsspp ? Just to make sure that the compression is not faulty, can you also try an .iso format game, un-compressed ?
                        ploinkploink @mitu
                        I just tried with the uncompressed (iso) version of the same game with ppsspp. I got the same error as previously when using ppsspp, I put the log from runcommand on pastebin:
                        https://pastebin.com/UwY2BBcr
                          I'll take a look when I get to my Pi4. Strange error, the PPSSPP package hasn't really changed recently and I don't remember this kind of errors when testing 1.13.2 som time back.
                            ploinkploink @mitu
                            Thank you! Much appreciated! <3
                              seems like someone else had the same issue with ppsspp running on libreelec with rpi4
                              but no solution in the thread though
                              https://forum.libreelec.tv/thread/23644-libreelec-rr-brave-spotify-moonlight-emulationstation-retroarch-pegasus/?postID=180228&highlight=ppsspp#post180228
                                The error seems similar, but with version 1.14.
                                I can't reproduce your error using the RetroPie provided binary package for PPSSPP or a source build for lr-ppsspp. I tried your game and another one, though both are in .iso format. I didn't find a pre-built CSO compressor for armhf and I don't have another OS handy right now.
                                Not sure what to try next - did you do any OS changes that could impact the normal operations, like overclocking ?
                                  ploinkploink @mitu
                                  No the only changes I did from default install was add emulators and switch roms and gameart to an external hdd
                                    tropicoco @ploinkploink
                                    @ploinkploink
                                    On my RetroPie system, this error was due tu a wrong kernel. And the wrong kernel was due to an upgrade to Debian 11 (which I should never have done) and downgrade to Debian 10.
                                    apt install --reinstall raspberrypi-bootloader raspberrypi-kernel
                                    and reboot solved the issue.
