    Screenscrapper not using given credentials
    screenscrapperscrapper
    4 Posts 4 Posters 416 Views
      Tarran
      So I have looked through existing topics and tried following the information given but for some reason I still can't see my credentials showing up in the command that will be run.
      I have gone to /home/pi/ where there is a symlink to /opt/retropie/configs/all/skyscraper and edited the config.ini file. I went down the [screenscrapper] section, removed the ; before it and the userCreds lines and added my credentials. But every single time I try to run the command it does not show the credentials as being part of the command.
      I am running skyscrapper 3.16.1 on RetroPie 4.8.9. I have tried rebooting with no luck
      S P 2 Replies Last reply Reply Quote 0
        sleve_mcdichael @Tarran
        @Tarran said in Screenscrapper not using given credentials:
        config.ini settings aren't passed as part of the command, so you won't see it there. If you watch the screen or check the log in RetroPie-Setup/logs it should say something like
        Fetching limits for user '**<sleve_mcdichael>**', just a sec...
        Setting threads to **2** as allowed for the supplied user credentials.
          perkinsarmand33 Banned @Tarran
          @Tarran HI @Tarran I'm Jameel Perkins asking is it Possible to stream my XBOX one x with Raspberry pi 400 in pc all at once yes or no please answer now if u can buddy thank u have a nice weekend ?
          mituM 1 Reply Last reply Reply Quote -1
            mitu Global Moderator @perkinsarmand33
            @perkinsarmand33 Please don't hijack other user's topics with your questions - open a separate topic instead. Also, if your questions are not RetroPie related, then maybe this is not the right forum to ask.
