    Help with Xbox360 Wireless Controllers
    xbox360xboxdrv
    2 Posts 2 Posters 999 Views
    • jons72J
      jons72
      Hello all, I am running an RPi2 with RetroPie version 3.6 or 3.7, I will have to verify when I get home (btw what's the best way to verify the version of RetroPie I am running?)
      I built an arcade cab and currently have a XinMo usb driver setup for 2 sets of arcade controls. I did not configure these controls, they were pre-configured on the Retropie image for me. These controls work great for me.
      What I want to do is now is add two Xbox 360 wireless controllers to fill in for players 3 and 4. I went through what I know, installed XboxDrv and setup the controls through emulation station but it will not recognize the controllers in emulators.
      Can someone help me with a step by step setting these up?
      Preferably I want my arcade sticks+buttons to remain player 1 and 2. Then force the xbox 360 controllers to be players 3 and 4.
      I appreciate any help I can get! :)
      I'll share a pic of the finished cab I built.
      • polishzeusP
        polishzeus
        I would not recommend using xboxdrv anymore. It used to be the go-to for 360 controllers but Xpad is now better. Here's some documentation on it:
        https://github.com/retropie/retropie-setup/wiki/Setting-up-the-XBox360-controller
        As for the version that you are currently running, there is no easy command to run to get this. Here is a Reddit post that mentions (in the comments) how to find out what version you have from Github which you'd then need to compare to what is on your screen.
        As I understand it, the reason there is not an easy, one-line command is because Retropie is not one big program. Instead it is a ton of smaller programs all bound together. If you think about the many emulators that you can run on Retropie, each emulation program has its own version. This might be an oversimplification but it is how I understand it from the research I've done.
        You can always follow this wiki update guide (same website as the top) to make sure you are on the latest but there is always the chance of messing up the current settings/controls you have set.
        Best case scenario for you, you will see xpad on the list of drivers, install it, and things work well. But my experience is that if you change one thing, others will be modified accidentally.
