    es_systems.cfg empty!
    kodiemulationessystem
    22 Posts 6 Posters 14.9k Views
      medicalengineer
      After installing Kodi from the Retropie config menu, my raspberry won't boot and claims that my es_systems.cfg is gone. Cannot enter with ssh or by server access. Have tried to re-run RetroPie setup but without positive results. I have tons of roms loaded on to the Pi and i would be so sad to lose all of 'em. I'm not with my Pi at the moment and i do not know how to get the error log. Please help.
        meleu @medicalengineer
        @medicalengineer can you log into your system at least?
          medicalengineer @meleu
          @meleu I am by default. It has been some time now, but i think i disabled the User/password function. I'm able to do functions like:
          cd RetroPie-Setup
          chmod +x retropie_setup.sh
          sudo ./retropie_setup.sh
            @medicalengineer then try to reinstall emulationstation.
              @meleu That's the weird thing. It says (installed) right next to Emulationstation. But could have another look at it.
                @medicalengineer yeah! It can be installed but you lost the es_systems somehow. If you reinstall you'll get this file again (I hope).
                  @meleu I tried to install it again. No success :( In the process of installing Emulationstation it does not mention something about es_systems.cfg.
                    edmaul69 @medicalengineer
                    @medicalengineer do you have a file named es_systems.cfg.bak in /etc/emulationstation/ ? If so delete es_systems.cfg and rename the other one. (Remove the .bak)otherwise i believe you need to delete es_systems.cfg file then reinstall emulationstation.
                      medicalengineer @edmaul69
                      @edmaul69 the es_systems.cfg is completly gone. Cannot find it on the Pi...
                        medicalengineer
                        I've located the es_systems config file, but it is empty, so i have to write it manually.
                        I'm home safe for now. Everything seems to work. But now it's time to get Kodi working with my RetroPie.
                        Any useful exp?
                        • 3lric3
                          3lric
                          /etc/emulationstation/es_systems.cfg
                          How were you able to find it to see it was empty, but not the location?
                          Anyway, the location above is where it belongs.
                            medicalengineer @3lric
                            @3lric After hours of searching i found it by at: /opt/retropie/configs/all/emulationstation/es_systems.cfg
                            I opened it just to find instructions how to write the systems manually.
                              BuZz administrators
                              that file will override the /etc/emulationstation/es_systems.cfg - if you have a full config file in /etc/emulationstation and you don't want to manually "manage" it yourself - remove the one in /opt/retropie/configs/all/emulationstation/es_systems.cfg
                                medicalengineer @BuZz
                                @BuZz uhm. I could have another look at it, but I didn't see any es_systems file in that directory. It is up and running with the es_systems i manually typed in some systems, and then updated trough RetroPie-Setup menu.
                                  BuZz administrators
                                  it should be unless it was removed/deleted. If you update all installed packages from the retropie-setup menu it will be recreated with the correct systems. You don't need to keep another copy unless you want to manually manage it.
                                  • DrMaxwellD
                                    DrMaxwell
                                    Or someone could just upload the file for you to mv into the directory and solve your problem.
                                      BuZz administrators @DrMaxwell
                                      @DrMaxwell The file is dynamic - differs depending on what a user has installed.
                                      DrMaxwellD edmaul69E 2 Replies Last reply Reply Quote 0
                                      • DrMaxwellD
                                        DrMaxwell @BuZz
                                        @BuZz said in es_systems.cfg empty!:
                                        es_systems.cfg is dynamically generated now? So, if I install say lr-mess, then every machine supported by the mess core will be generated in the es_systems.cfg as a system?
                                          edmaul69 @BuZz
                                          @BuZz this reminds me, somehow my roms changed to root and not home. I had to give user pi permissions to /home/pi/ to be able to move back to that but the es_systems.cfg in /etc/ keeps setting the roms in root. Not a big deal because i manually manage my systems in opt but would like to fix it if possible.
                                            @DrMaxwell No. I didn't say that. But if you have only 2 emulators installed, only the relevent systems will be set in that file.
                                            DrMaxwellD 1 Reply Last reply Reply Quote 1
