    [Solved] Roms won't launch after Selph Scraper, runcommand error
    scraperruncommand
    3 Posts 2 Posters 1.8k Views
    • 7
      777
      Fresh 4.0.2 install, 8 systems. gba,gbc,mastersystem,megadrive,neogeo,nes,pcengine,snes. After installing roms they launch as should and everything is working. However after installing Steven Selph's Scraper, no roms launch, error message below. Same error message if I only install the scraper and try to launch and after scraping all games. Same issue with v4.0. v3.8.1 working.
      Pi Model: 2B v1.1
      RetroPie Version Used: 4.0.2
      USB Devices connected: Keyboard
      Controller used: iBuffalo SNES controller
      Error messages received:
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 653: syntax error near unexpected token i//' /opt/retropie/supplementary/runcommand/runcommand.sh: line 653: for cpu i// Inferno utils/8c/mul.c'
      Guide used: https://github.com/RetroPie/RetroPie-Setup/wiki/scraper
        meleu @777
        @777
        I don't know why it happens after use sselph scraper, but based on the error message it seems that your runcommand.sh has some problem.
        I would suggest you to update your runcommand:
        1. go to RetroPie-Setup
        2. Update RetroPie-Setup script
        3. Manage Packages -> Manage Core Packages -> runcommand -> Install/Update from binary
        and then try to launch your game again.
        • 7
          777
          Thank you for the help, roms launch now after following directions.
