    Vice Sound Buffer Issues
    vice sound
    5 Posts 2 Posters 2.4k Views
      as692
      Updated Vice this morning and now getting a sound buffer overflow error.
      Anyone know how to fix it?
        as692
        Found the issue....if I turn off "double Size" in the video setting and turn the sound back on again it works. Only issue is I have to do this ever time I restart as saving the settings does'nt remember it. I'm using a RPI 3.
          edmaul69 @as692
          @as692 do you have save on exit turned on in the options? With that and save settings i have no problem.
            as692
            Thanks for the reply but I've tried this now and it still won't save those settings
              edmaul69 @as692
              @as692 there is an audio setting and it is set on something like exact. I changed it and it started working correctly. I can look later to find the exact setting for you.
