    MSX Problems
    msx
    3 Posts 2 Posters 1.4k Views
    • N
      Nayin
      I can not run no MSX rom, I added all the bios files, and this is my runcommand.log
      Allocating 16kB for empty space...
      Opening MSX2P.ROM...OK
      Opening MSX2PEXT.ROM...OK
      Patching BIOS: 00E1..00E4..00E7..00EA..00ED..00F0..00F3..OK
      Opening DISK.ROM...OK
      Allocating 128kB for RAM...OK
      Allocating 128kB for VRAM...OK
      Loading DEFAULT.FNT font...FAILED
      Loading optional ROMs: KANJI.ROM..RS232.ROM..OK
      Found MSXDOS2.ROM:
      Cartridge C: 64kB GENERIC/16kB ROM..starts at FFFFh..OK
      Found PAINTER.ROM:
      Cartridge D: 64kB NORMAL ROM..starts at 401Dh..OK
      Found FMPAC.ROM:
      Cartridge E: 64kB FMPAC/SRAM ROM..starts at FFFFh..got 16kB SRAM..OK
      Found /home/pi/RetroPie/roms/msx/AshGuine 2 (Japan).rom:
      Not a valid cartridge ROM
      Redirecting printer output to STDOUT...OK
      Initializing VDP, FDC, PSG, OPLL, SCC, and CPU...
      Attached normal joystick to joystick port A
      Attached nothing to joystick port B
      228 CPU cycles per HBlank
      59736 CPU cycles per VBlank
      262 scanlines
      RUNNING ROM CODE...
      EXITED at PC = 045Ch.
      Mode 65554, RAMPages 8, VRAMPages 8
      Does anybody can help me?
        edmaul69 @Nayin
        @Nayin which msx emulator are you running? Have you tried others? I think the one i use is lr-bluemsx.
        • N
          Nayin
          I'm using bluemsx and fmsx.
