    Retropi not allowing 2 player with ipac2
    retro pi ipac2only 1p workshelp
    43 Posts 5 Posters 19.4k Views
    • theinkT
      theink @rolrod66
      @rolrod66 Can you tell me what these other two buttons are intended for? The exit and display I mean. I see that you have a matching pair for each player.
        rolrod66 @theink
        @theink it was save and load, but I went with your layout.
        By the way you did an excellent job on the post. I can't thank you enough. It's help me out a lot.
        theinkT 1 Reply Last reply Reply Quote 0
        • theinkT
          theink @rolrod66
          @rolrod66 Glad to hear it. Share some thoughts. I would be interested to know if I everything worked straight out for you.
          Did you get how the controller map images are supposed to be used?
          If there is something unclear I can try to improve the text.
          It would probably be better if you comment on the other post cause this one turned out pretty messy.
          Take care. :)
