    Emulators missing on RetroPie 4.0.2 / Retropie possible on VMware? - HELP!
    vmwareretropie 4.0.2missing packageemulatorhelp
    4 Posts 2 Posters 5.2k Views
      r34per
      Hi All, I am a newbie to the Raspberry Pi world so please be patient.
      I recently bought a Raspberry Pi 3 and downloaded RetroPie 4.0.2. After installing it I noticed the some emulators were missing from my home screen. I checked a few forums (mostly this one) and found that the emulators do not show up on Emulation Station unless there are ROMS present for that emulator. I then used WinSCP to connect to the Pi and navigated to RetroPie/roms. I found a few folders in there such as NES and SNES but there were a few that are missing, the Atari ST, Atari 5200 and Nintendo DS among others.
      Do I need to install those separately? if so can anyone point me in the direction on how to do this?
      Also I is the RetroPie compatible with VMware? I like to get practise with the Linux coding side of it but don't always have access to my Pi from work.
      Any help will be greatly appreciated. Thanks
      • herb_fargusH
        herb_fargus administrators @r34per
        @r34per if I had a dollar...
        https://retropie.org.uk/forum/post/27304
        Anyways vmware no. With the latest pixel raspbian release you can use realvnc but won't work with emulationstation etc.
          r34per
          Thanks!! I did try to search for it but I guess I was using the wrong terms.
          • herb_fargusH
            @r34per actually I lied to you sorta. I almost forgot that RetroPie isn't strictly for the raspberry pi. You can also install it on x86 (Ubuntu) which you can install on a virtual machine. There are just some slightly different packages due to the diff platforms.
            https://github.com/retropie/retropie-setup/wiki/RetroPie-Ubuntu-16.04-LTS-x86-Flavor
