Help with both Commodore64 and Dreamcast needed!
Im a beginner of all this with retropie.. but i found out that i can get my old childhoodlove Commodore64 on to it, correct?
I found a downloadable file.. contains both a lot of roms and also a lot of other folders and files..
the question is if i copy all of it to my Commodore 64-folder on the memorycard in the retropie, or do i have to do something more?Also.. i found a large .cdi-file that is told to be containing a lot of Dreamcast-games.. but some people said that it just not as simple as coping it on to the correct folder of the memorycard.. but that i also have to install some kind of thing into the retropie?
Would appreciate some help :)
Videoguides are not my strong side.. but ill check it out! :)
if someone else have a simple solution on the CDI-file "problem" please comment :)
@najkks said in Help with both Commodore64 and Dreamcast needed!:
Thanks for that. Your best bet is:
Good luck.
Btw.. do you know how much space is needed for the "retropie" -system on the card?
i think i currently have about 15.4gb of roms that i would like to use
